ZenEee (Zenwalk on EeePC)
Posted 28 December 2007 - 02:19 PM
I have started this new project. The goal is same of EeeOS. ZenEee is designed to be a minimalistic custom Zenwalk-core distribution ( light-core-base, xorg, fluxbox only). The users of ZenEee will can configure and build their own system with the netpkg tool (aka apt-get from Debian). The official forum (in french) is here. For english user, you can use this section for your question and answer.
alisou, :-)
http://alixe.org (AliXe is a SLAX-based live cd/usb)
Posted 29 December 2007 - 02:26 AM
Edited by vvlist, 29 December 2007 - 02:37 AM.
Posted 29 December 2007 - 03:09 AM
Posted 29 December 2007 - 06:21 PM
Posted 29 December 2007 - 07:57 PM
Thanks Alisou.
Posted 31 December 2007 - 05:17 AM
I'm getting frustrated, if someone like you with more experience manages to make a fully working Zenwalk for the EEE, it would be great.
Posted 31 December 2007 - 05:28 AM
Posted 31 December 2007 - 05:43 AM
http://support.zenwa...?topic=11201.30
Basically I installed 5.0, applied the MadWifi patch, and had to create a file under /etc/modprobe.d in order to get Wifi and Sound working...
Posted 31 December 2007 - 09:21 AM
Posted 31 December 2007 - 03:33 PM
«ZenEee-USB Beta1» is now installed on a 1GB usb key and I can start the eeepc. ZenEee is Zenwalk-Core-light 4.8 + Xorg + Fluxbox. The kernel is not optimized for eeepc. The kernel has not yet been recompiled. This is the reason why the beta1 is not available to the public. I work on beta2. The changes are as follows:
* Deleting fluxbox, adding xfce
* Recompiling the kernel with the eth0 driver
* Adding the windows driver for the wireless card
* Adding Iceweasel for web surfing
Beta2 version will be available in sharing.
An howto for install on usb stick will be available.
I will go see this thread on the Zenwalk forum. Thank for this link rozojc.
Also i give you this link for French ZenEee forum on Zenwalk.fr
Greetings!
alisou
Edited by alisou, 31 December 2007 - 03:36 PM.
However, there are too many things not working for me to continue wrestling with this, I will just go for eeeBuntu (not eeeXubuntu) for the moment, and wait if someone with more knowledge than me makes a particular Zenwalk version for the EEE...
#12
Posted 31 December 2007 - 03:39 PM
Greetings!
alisou
1. Why use the Windows driver? Asus already released a patch for MadWifi, and I did try it successfully (except for the increased booting time). Using ndiswrapper would increase CPU usage, and there are native Linux drivers...
2. WHy not base it on Zen 5.0? That way it will last a little longer before it is outdated.
3. If you could also apply ASUSs ACPI patch,it would be great as you could make Function keys, etc. work.
4. The other thing that did not work in my attempt was webcam, take a look at that.
5. Keep us posted!
#13
Posted 31 December 2007 - 06:52 PM
@rozojc
I make the distro gradually because many things are new to me. So the final version will be as follows:
* Light Zenwalk-core 4.8 + Xorg + Xfce
* Optimized kernel for eeepc (wireless, Lan, webcan, acpi drivers)
* Some applications (Icewaesel, Pidgin, ???)
I don't use Zenwalk 5.0 Beta version. For the moment, i want to use stable version of Zenwalk.
Voilà!
Keep us posted!
#14
Posted 31 December 2007 - 09:43 PM
#15
Posted 05 January 2008 - 10:58 AM
Here are the results obtained:
* Zenwalk-Core-light 4.8, kernel 2-6-22-9
* Xorg, Slim
* Fluxbox& Rox for WM
* Iceweasel, Leafpad
* LAN with compiled atl2 driver
* WLAN with compiled madwifi-ng driver + wpa_supplicant
* bootable USB key with grub
I am doing a new installation of Zenwalk
I will install on usb key
I will do an disk image for sharing (Beta2 version)
Voilà!
alisou, :)
Edited by alisou, 05 January 2008 - 11:01 AM.
#16
Posted 05 January 2008 - 02:39 PM
Did you also include ACPI drivers provided by ASUS? What things work and which dont work out of the box?
#17
Posted 05 January 2008 - 02:50 PM
Asus-acpi driver and webcam driver will not included in the Beta2 release, only on Beta3 release.
a+, alisou, :-)
#18
Posted 07 January 2008 - 12:33 AM
#19
Posted 25 January 2008 - 10:16 PM
Keep up the great work, I'm looking forward to trying Zenwalk.
#20
Posted 28 January 2008 - 05:21 AM
