USB Hub + Bluetooth + GPS + Flashdrive + Card reader + FM transmitter
83 replies to this topic
#1 ivc
  • 108 posts
Posted 23 December 2007 - 12:24 AM
This has been my little project the last couple of weeks. A massive internal modification to my Eee 4G.
It includes the following:
● 2x USB hubs
● Bluetooth 2.0+EDR
● GPS module with antenna
● Voyager GT 4 GB flash drive
● SDHC card reader
● FM transmitter
● Draft-N wireless adapter with a third antenna from a Wii.
● Everything connected via a dip switch
It's quite weird that Asus decided to leave that much free space unused in the Eee. The Eee could be slimmer and thinner if they really wanted to.
Anyhow, let the pictures tell their story. I've created a Wiki page with all the nitty gritty details.
Eee Internal Upgrades Wiki page
Pictures:
USB hubs
The first USB hub mounted next to the memory bay:
Posted Image
Second USB hub over SSD drive:
Posted Image
GPS
GPS DIY kit from Ebay stripped down to only the necessary parts:
Posted Image
GPS antenna mounted on the left-side of the display. I had to remove 4 plastic stubs to make it fit:
Posted Image
GPS module mounted over the ethernet and audio chip:
Posted Image
Bluetooth
Bluetooth adapter mounted under the GPS antenna on the left side, for good reception:
Posted Image
SDHC card reader
SDHC card reader placed over the wireless adapter:
Posted Image
But kicker is that there is a gap in the memory expansion bay to fit a SDHC card that can actually be removed after the machine is put together again:
Posted Image
Sideview:
Posted Image
Flash drive
Fast Voyager GT 4 GB flash drive used as a second OS boot drive. The controller is from Silicon Motion, the same vendor as the SSD-drive, and uses the same type of NAND flash chips as well:
Posted Image
Flash drive mounted on top of the wireless adapter:
http://imgboot.com/i...rivemounted.jpg
FM transmitter
FM transmitter to wireless transfer audio the any FM radio in the vicinity of 5 meters. Should be great for roadtrips:
http://imgboot.com/i...mitterfront.jpg
FM transmitter mounted nicely in the space between the DC-jack and ethernet/modem-ports. Ttight space, many wires. Wires for audio, antenna, power and buttons to change frequency (buttons in expansion bay):
http://imgboot.com/i...nsmittertop.jpg
802.11n wireless adapter
New Intel draft-N 300 MHz wireless adapter:
http://imgboot.com/i...wifimounted.jpg
Power switch
I don't like to trust the USB devices to conserve energy when they're idle. Therefore I've installed a DIP switch in the expansion bay to make it easy to switch off the devices I don't use. The power switch is mounted with double-sided foam tape and can easily be moved to remove the RAM module if needed. For power and ground 26 AWG and signal 30 AWG Tefzel insulated wires (from Habia). Multi-stranded wires for the audio cables.
http://imgboot.com/i...erswitchbay.jpg
Overview
This is the complete installation. Showing the bottom of the motherboard were most of the free space can be utilized.
http://imgboot.com/i...boardbottom.jpg
Top view of the display and top motherboard without the front panels. FM transmitter and third draft-N antenna on the right.
http://imgboot.com/i...iewcomplete.jpg
For a few more detailed pictures, check the wiki page mentioned above.
I summarized the costs and it turned out to be 454.38 USD - including 2 GB RAM upgrade, 8 GB SHDC card, and shipping to Europe, details on the wiki page.
Future projects include desoldering the NAND flash chips and install new chips taken from Voyager GT flash drives, install HSDPA 3.6 Mbit/s modem in expansion bay, new custom made copper cooling elements, and probably some smaller tweaks to the current mods.
Hope you enjoyed my little shenanigans. :)
Edited by ivc, 26 December 2007 - 02:54 PM.
#2 peter_was_here
  • 83 posts
  • LocationBrisbane, Australia
Posted 23 December 2007 - 12:49 AM
there aren't even words to describe how awesome this is! could you run a test with everything on to see how it hits battery life?
White Eee 4G 701 7B model FOR SALE! Selling it to buy an MSI Wind PC
#3 Johnx
  • 75 posts
  • LocationUK
Posted 23 December 2007 - 01:02 AM
All hail ivc! Amazing, no other words to describe this.
#4 vvlist
  • 63 posts
  • LocationThe Pacific Northwest
Posted 23 December 2007 - 01:08 AM
Are you running Linux with these mods? If so, does it all work?
White ASUS 701 4GB 512MB ram
#5 pingu
  • 1 posts
Posted 23 December 2007 - 01:09 AM
Hi and well done. Thats a whole lotta hacks, neatly done.
#6 marcoeee
    Moderatore Italiano
  • Moderators
  • 612 posts
  • LocationItaly
Posted 23 December 2007 - 01:40 AM
OOOOOOOOOOOOOOOOOOOOOOOOOO
Oh my...
Seems cheap and chic!
How much did consumption and weight grow?
Now u need just infrared usb, fingerprint reader, sim reader, portable printer inside. touchscreen, hspda 3G modem, and it's ready for next 007 movie.
This is a complicated work, but still one of most accurate and polished. U r great!
Go on like that!
ciao ;)
.it Moderator
USB Hub integration without soldering PROJECT! (Camera connector)
eee901 XP WHITE, Adata SDHC 16GB Eee Edition WHITE, WesternDigital 2,5" 250GB HD WHITE !!!
#7 TeamMCS
  • 112 posts
  • LocationLondon
Posted 23 December 2007 - 02:12 AM
Thats really impressive, may I ask, what wiring did you use?
Cheers Miles :)
[4GBlack EEE. Touchscreen, 2gig, Bluetooth, WinXP] < Space is getting a little spare now! Could this be the end of the mods on *this* device?!
#8 pvillasuso
  • 76 posts
Posted 23 December 2007 - 02:23 AM
Insane ! WTF ! I`m Very impressed !
Congrats.. just add a touchscreen , and you`re all done ! Hehe
Awsome dude !.. wish I had the balls and knowledge to do something like that !
Clean & Nice hack !
#9 Haku
  • 456 posts
  • LocationGlos. UK
Posted 23 December 2007 - 02:38 AM
Ever since I started looking into the Eee and then ordering one shortly afterwards I've been looking forward to the numerous hacks & mods people will do to these because they're so cheap for what they are.
I have to say I'm quite astounded that you've managed to fit so many extra devices into the thin shell of the Eee, excellent work, and at the rate of hackings, it seems about once or twice a week someone posts here with reportings of soldering wizardry often with new variations on the previously reported mods or new devices implimented.
I will get round to modding this Eee one day, but stil trying to work out what I want to mod it with! a 16gb fast flash drive is definitely going to be added, but after that I can't think what else I'd want.
#10 Neodudeman
  • 190 posts
Posted 23 December 2007 - 02:52 AM
That was the most amazing thing I've ever seen.
How'd you make everything so pristine and clean looking? The wires you used seemed like they were made Specifically for your mod.
This is the most impressive thing I've ever seen. Everything just worked out Great! To be honest, I'm a little jealous of your Asus. lol. I would love the advanced simplicity and beauty of your computer, but alas, I must settle for externally attached peripherals.
I love my Asus,
It is with me everywhere,
And does everything.
#11 Kermee
  • 212 posts
  • LocationSeattle, WA, U.S.A.
Posted 23 December 2007 - 02:56 AM
HOLY SMOKES! That is just AWESOME! I'm speechless. Kudos!
Cheers,
Kermee
ASUS Eee 1000H Black @ 160GB Seagate 5400 - 2GB DDR2-667 - XP Pro SP3 *Full* Retail - Intel 4965AGN
ASUS N10J-A1 @ 320GB WD Scorpio - 2GB DDR2-800 4-4-4-12 - Vista Premium *OEM* - ForceWare 180.42 (21/10/2008)
#12 Fluffywings
  • 460 posts
  • LocationSaskatchwan, Canada
Posted 23 December 2007 - 02:57 AM
Wow. Other then this sentence I am speechless.
#13 gospeed.racer
  • 1,616 posts
  • LocationPortland, Oregon USA
Posted 23 December 2007 - 03:51 AM
That is truely a work of art, and something all of us can use as a benchmark. Kudos!
Sorry, retired from the cables business!
#14 Elddric
  • 268 posts
  • Locationmd.usa.NA@earth.sol.milkyway
Posted 23 December 2007 - 04:21 AM
There are some posts that are eh... there are others that deserve proper praise. This is one of those. This post is a great collection of ideas. I samefully claim that I WILL be useing a few of these as my own.
<bowing>
I am not worthy, I am not worthy!
</bowing>
Thank you for insparation and for instructions for those of us always looking for new ways to mod. I also praise you for listing all those other great moders who's knowladge you used in your wiki page. Props to all the great info out here and to the people who provide it!
Edited by Elddric, 23 December 2007 - 04:23 AM.
8G(702)7B-0404 bios-8GB SSD(XP)-2 8GB SDHCC6(storage)(Xandros)-2GB ram-touchscreen+bluetooth
astray+
EEEctl(Full speed)
IVC's research Read his resources. GREAT info from a lot of people!
#15 nicolasg
  • 277 posts
Posted 23 December 2007 - 07:09 AM
Excellent work, especially on the wire routing.
The only addition I can possibly imagine, moving the power control dip switches to a software controllable solution.
tristad (http://forum.eeeuser...pic.php?id=3735) did it using the SMbus and PCF8574 I/O expander. (under linux)
Webcam wireharness/connectors available. PM for info.
4G EEE 701. Touchscreen, GPS, Bluetooth, serial port.
#16 Jon Bradbury
  • Moderators
  • 2,637 posts
  • LocationUK
Posted 23 December 2007 - 09:52 AM
Yes, the wire routing is well thought out and neatly executed.
I have a slight concern about airflow when the fan is on. Have you been monitoring the temperatures?
#17 hollander172
  • 4 posts
Posted 23 December 2007 - 11:48 AM
I'm very interested in the performance of the GPS receiver. Nice to see the antenna fits in the screen casing.
#18 angel eyes
  • 51 posts
Posted 23 December 2007 - 12:36 PM
that is amazing!
#19 marcoeee
    Moderatore Italiano
  • Moderators
  • 612 posts
  • LocationItaly
Posted 23 December 2007 - 01:32 PM
ciao ;)
.it Moderator
#20 Jama
  • 91 posts
Posted 23 December 2007 - 03:45 PM
I think what others have said is what i am about to say, ill say it anyway though.
<awe> This has got to be the most advanced, usefull and cleanest mod yet (In my opinion). </awe>
Lol well great job, waiting for your next mod :D
Jama
Edited by Jama, 23 December 2007 - 05:00 PM.
