I know there are quite a few guides out now, but I decided to do this one just to tie in everything I've found and also give a guide to vLiting windows 7, as that seems to be a common request. Also, to save people from a few problems I had, i.e. forgetting to untick "unnatended setup" meaning I get no access to the repair options in the installer.
Needed:
-Windows 7 image with key - http://www.microsoft...a-download.aspx
-vLite - http://www.vlite.net/download.html
-Automated Installation Kit (AIK) for Windows Vista SP1 - http://www.microsoft...&displaylang=en
** Dont ask me for help with AIK problems, google is your friend, your problem has been solved several times over **
-SD Card or USB-Drive with 2GB or more space
-kazunis driver pack - http://www.sendspace.com/file/7vay7c **any objections to me using this, let me know, and i'll do my own**
-Bios Flashed to version 1001 or 1101 if using a 901 **Search the forum, plenty of existing guides**
Thanks go to Kazuni and birdibird for their guides which I used to get to this point.
Pre)Install vLite as you would any other application. Start it, and follow the instructions for the AIK. Once complete, close vLite.
1) Use WinRar, or 7z or your favourite program to extract the windows image.
2) If running vista : Once the image is extracted, insert your SD card/USB Drive.
a)click start, type in command, then when "Command Prompt" appears, right click on it and select "run as administrator"
b) Type "diskpart", followed by "list disk". Find the SD card or USB drive, and note it's number.
c) Type the following
select disk # <-- substitute your sd/usb number
clean
create partition primary
select partition 1
active
format quick fs=ntfs <-- if this doesn't work type format quick fs=fat32 instead
assign
exit
3)If running xp : Once the image is extracted, insert your SD card/USB Drive.
a) Right click on the disk, and use the windows format utility.
b) Format as NTFS or FAT32 (NTFS is faster, though the option may not be there)
c) Open a command prompt
d) Navigate to the folder where the you extracted the files to. i.e. for C:\Win7\Files type "cd C:\Win7\Files" (without quotes)
e) Navigate to the subfolder "boot"
f) Type "bootsect.exe /nt60 x:" (without quotes) where x is the usb drive letter
4)There isn't a 4 anymore, integrated into step 2+3
5) Copy all of the following into notepad, save it as "Win7.ini" (Include the "", as it forces notepad to save it with the .ini extension). Copy the file into the presets folder, under the vLite installation directory. Mine was C:\Program Files\vLite\Presets
; vLite preset file ; ;#Environment: ; vLite v1.2 ; Framework 2.0.50727.1434 ; Microsoft Windows NT 6.0.6001 Service Pack 1 32-bit ; ;#Target: ; Windows 7 ULTIMATE 32-bit ; Version 6.1 English (United States) ; [Compatibility] ACDSee / XnView DVD Treasury Halo 2 Hauppauge WinTV Logitech Setpoint MediaPortal Zoom Player Aero Glass File and printer sharing (Server) Internet Explorer Recommended Scanners and Cameras Windows Update [CustomHide] [Components] ;# Accessories # Accessibility Games-Inbox Games Games-Premium Inbox Games Snipping Tool Speech Support ;# Drivers # Diva Server Modems Printers-Generic printer QLogic Fibre Channel Adapter Scanners Storage controllers-Adaptec Storage controllers-Elxstor Storage controllers-IBM ServeRAID Storage controllers-ICP vortex Storage controllers-Intel (Matrix) Storage controllers-nVidia Storage controllers-SiS Storage controllers-Via TV Tuners-ADS Technologies TV Tuners-ASUSTeK Computer Inc. TV Tuners-AVerMedia Technologies, Inc. TV Tuners-Compro Technology Inc. TV Tuners-Creatix TV Tuners-Hauppauge TV Tuners-KNC ONE GmbH TV Tuners-KWorld TV Tuners-Lumanate, Inc. TV Tuners-Philips Semiconductors TV Tuners-Pinnacle Systems TV Tuners-TerraTec Electronic GmbH TV Tuners-VidzMedia Pte Ltd. ;# Hardware Support # Dynamic Volume Manager Fax Support Firewire (1394) Floppy Disk Support Internet Small Computer System Interface (iSCSI) Microsoft Multi-Path Bus Modem Support TV Tuner support Windows HotStart XBOX 360 Controller ;# Languages # Arabic Brazillian Bulgarian Croatian Czech Danish Dutch Estonian Finnish French German Greek Hebrew Hungarian Italian Japanese Korean Latvian Lithuanian Norwegian Polish Portuguese Romanian Russian Serbian Simplified Chinese Slovak Slovenian Spanish Swedish Table Driven Text Input Processor Thai Traditional Chinese Turkish Ukrainian ;# Multimedia # Intel Indeo Media Center Music and Video samples Sample Pictures Screensavers SideShow Wallpapers ;# Network # Connect to a Network Projector Distributed File System (DFS) Internet Information Services (IIS) Remote Desktop and Assistance Remote Desktop Client RIP Listener Telnet Client Telnet Server TFTP Client Windows Collaboration Windows Mail ;# Services # Remote Registry TPM Base Services Windows Search ;# System # BitLocker Drive Encryption Disk Quota Help IMAPIv2 Burning Support Microsoft Client For NFS Natural Language Parental Controls Performance Counters Reliability and Performance Monitor Remote Differential Compression Run a legacy CPL elevated Sync Center Tablet PC Windows Easy Transfer Zip Folder [Options] DEP (Data Execution Prevention) = Default User Account Control (UAC) = Enabled AntiSpyware Realtime Protection = Default Memory requirement = 256MB AutoPlay = Enabled Paging Executive = Enabled Power scheme = Power saving Power button = Default Sleep button = Default Control Panel - Classic View = Default Show hidden files and folders = No Show protected operating system files = No Show extensions for known file types = No IE Phishing Filter = Default IE Phishing Verification Ballon Tips = Default [Services] [Protection] [Drivers] [Unattended] [Hotfixes] [LanguagePacks]6) Once the image has extracted, open up vLite again. On the first screen, you're greeted by a drop-down box with a browse button next to it. Click Browse, and navigate to the folder with the files you just extracted, the click ok. vLite will think for a bit, then ask you which version you want to configure. Select the Ultimate version. vLite will think a little more. Once it's done, the next button will become clickable, so click it.
7)"Components", "Tweaks", "Bootable ISO" and "Enable before apply" should be ticked, untick the others. Click Next.
8)Click Presets >> Load >> Win7
9) Click next. You may tweak a few of the defaults here, but most can be changes once you're up and running anyway, so click next again.
10) Click "Apply", make sure "Rebuild one (Ultimate)" is selected, then OK.
**Get yourself a cuppa, it takes about 5-10 mins**
11-Optional) Once vLite has finished, Click next, type in a label, then click "Make ISO". Choose a filename, and go. You don't need to do this, but it gives you an iso file to store the install for easy use if needed.
12)You can close vLite now. Navigate to the folder where you extracted the files to earlier, and chose in vLite in step 6. there should be 4-5 files, and 4 folders like so:
13) Copy all the files and folers to your SD card/ USB Drive. Now make a folder and name it Drivers. open it and extract the files from the driver pack to here.
14) If not already, insert the SD card/USB Drive into your EEE
15) Turn it on/Reboot, at the bios screen, hit "esc" until the boot selection menu appears. Choose your SD card or USB drive
16) The installer should have booted up to first install screen. It should look like the image below.
17)Choose your language, time and currency format, and keyboard then click next. You should be at the screen below. If not, and you're at the eula acceptance screen, or the disk selection screen, then you didn't follow my instructions. Turn the computer off, and either boot up the eee into it's normal os, or put the SD card/ USB drive in another computer. Open it up, and there'll be a file named "autounattended.xml". Delete it. Start back from step 14.
18) Click "Repair your computer". Ignore the next screen and just click next as soon as you can.
19) Click on "Command Prompt" then type "diskpart" followed by "list volume". Find your secondary SSD* and note it's drive letter.
On my 901 Linux it's the biggest, so should be the same for you, assuming your sd card or usb drive isn't bigger.
20) Type "exit" then "setup /tempdrive:#" where # is the secondary ssd drive letter.
21) Choose you language etc. again.
22) Accept the license terms (if you do..) and click next.
23) If you get a choice between Upgrade and Custom (advanced), choose custom.
24) If the first disk has any partitions, click on "Drive options (advanced)". Click on the partition(s) then click delete. Be careful not to delete the partition for your secondary ssd, if you want to format it, do it from windows later.
25) You should now have "Disk 0 Unallocated Space" and "Disk 1 Partition 1" (it doesn't matter if there's multiple partitions on disk 1). Click on "Disk 0" then next. Say yes to any prompts. now go have another cuppa, in 20-30 mins, you should be at a prompt to enter a username. If it's still installing, wait some more.
26) Enter a username, and follow through the screens until you're at the windows 7 desktop. Success! Windows 7 is installed, but we're not done yet.
27) Click start. Type cmd.exe and right click it when it appears. Click "Run as Administrator" and accept the UAC prompts.
28) Type powercfg /h off <-- this saves a crapton of space by disabling hibernation and deleting the hibernation file.
29) Click start, right click My Computer then Properties. Click "Advanced system settings" then "Settings" under "Performance". Click Advanced. Then "Change" under "Virtual Memory". The Drive List should be grayed out and the C: drive should have NONE under "Paging file size(MB)". If not, untick "Automatically manage paging file size for each drive", Click c:, select "no paging file" then Click "set". **Optional** Click on the secondary ssd drive, and select "System managed size", then "Set".**Optional** Click OK, OK, OK. Click "System Protection", then select the C: drive in the box. Click Configure and select "Turn off system protection". Click OK, OK then "Restart Now". (Make sure you boot from windows, not SD or USB. At the bios screen, press F2 and make sure camera bluetooth wireless and lan are all enabled.
30) Back in windows. Time to install drivers. Go into the drivers folder on the SD card/USB drive.
**for the next 5 steps, ignore prompts to restart the computer**
31) Go into WLAN then run DPInst.exe
32) Right click on My Computer and click properties. Go to Device Manager. Find Ethernet Device, right click on it and click "Update Driver Software". Click "Browse my computer for driver software" and direct it to the LAN folder in the driver folder, then click next. Once done, click Finish/Close
33) Expand Display Adapters, right Click on "Mobile Intel ....." and click "Update Driver Software". Do the same as above, but direct it to the VGA folder.
34) In the drivers folder, run AsusACPI_xp0400b09.exe.
35) Run SuperHybridEng_1.02.exe
36) Restart the computer. Boot from the SD card / USB Drive. Click on repair my computer again, then next, then Command Prompt.
37) Do a diskpart, then type list volume, and figure out which drive letter is which drive. Win7 creates a small 200mb partition on my computer, and here it gets labeled as C: and my usual C: is now E: if yours is the same, do the following, otherwise, substitute the correct letter.
(For me C: = 200mb partition. D: = secondary SSD, E: = Usual C: partition)
robocopy "E:\Program Files" "D:\Program Files" /copyall /e
del "E:\Program Files" /f /s /q /a
rmdir "E:\Program Files" /s /q
mklink /j "E:\Program Files" "D:\Program Files"
-exit and restart
Once you've rebooted, you have yourself a shiny new windows 7 install! Now go! Play!
Optional:
Move Temp folders and Document folders to secondary SSD
Right click My Computer > Properties > Advanced system settings > Environmental Variables.
In the top section, modify TEMP and TMP to a folder on the secondary SSD. Also, do the same with TEMP and TMP under system variables. It may also be a good idea to note down the paths to these folders to clean them out manually to reclaim some space. Once they've been changed, OK a few times.
Now the Documents. It's simple, but a tad tedious.
Navigate to C:\Users\<UserName>
Right click on each folder, one by one, and click properties. Click Location, then change C:\ to D:\ and ok it. It'll ask if you want to move files, say yes. You'll still have the C:\Users\<username> folder, but your documents, music, pics, vids etc will be on the secondary ssd, and everything will be linked automatically.
I may add more tips if I come across any more.
Thanks go to Kazuni and birdibird for their guides!
Edited by keyz182, 07 April 2009 - 06:52 PM.
