UUID mounting?
Posted 14 December 2007 - 01:19 AM
The /dev/disk/by-uusid directory present on my ubunto boxes is missing on Eee... (actually /dev/disk/ is missing).
Can't seem to get a straight answer if uuid is a kernel feature, or a module, or what...
Posted 15 December 2007 - 05:41 AM
Okay, so the good news is that Xandros linux does have mount -U insert-uuid-here functionality
the bad news is the busybox, which needs to mount the root file system, does not.
The good news is that dumpe2fs -h /dev/foo will tell you the UUID of the disk you want to put in your init or menu.lst
But busybox mount won't take the -U option. Even in newer versions of the source on CVS on the busybox project site.
Argh! how is this supposed to work?
I did find that the UUID can be read directly from an ext2/3 file system at offset 0x468-0x467
ie, dd if=/dev/sda1 bs=8 count=2 skip=141 | hexdump will yield the UUID without the usual dashes.
But trying to recompile busybox with addition programs is turning out to be a pain. I'd need something that did a find
and a for each kind of thing and then checked the UUID and produced a /dev/sdxn type result to pass to mount.
There's got to be a better solution for reliable usb booting...
Posted 15 December 2007 - 06:34 AM
Also, when I unpack the initrd.gz of Ubuntu, I found that they have no /dev, but it is rather created by udev. There are the udev files in /sbin and /lib/udev of initrd. So I think the difference is that in eeepc, the udev files resides in the root partition, whereas in Ubuntu, they pack them into the initrd.
This weekend, I will also compare the kernel .config files of Ubuntu and eeepc to check if anything is missing in the kernel.
Posted 15 December 2007 - 07:31 PM
Incidentally, how did you get into your ubuntu initrd image? I haven't figures out the right combination of unzipping and loop mounting or cpio extracting to do so yet.
I do have one other idea for a quick fix: the file /proc/partitions lists the size of each partition. We could use sed to extract the /dev/sd?? name from that, much as the default extracts it from the kernel command line, by looking for the known size of the partition we want to mount (ordinarily I'd use grep -o but this busybox configuration doesn't seem to support that option)
Of course this won't work if you have multiple partitions of the same size, such as my flash stick containing a dd copy of the internal SSD...
Another good menu choice might be to ask the user what partition to mount after they see the usb detection, with the option of retrying if that one doesn't work.
Edited by tuxpocket, 15 December 2007 - 07:33 PM.
Posted 16 December 2007 - 12:16 AM
it now takes parameters of the form
root=label:VOLUMELABEL
or the traditional
root=/dev/sdb1
Here is my init
mount -t proc proc /proc
#load usb modules - this won't work unless you have
#copied them into the image
echo loading usb modules
insmod -f /modules/usbcore.ko
insmod -f /modules/ehci-hcd.ko
insmod -f /modules/uhci-hcd.ko
insmod -f /modules/libusual.ko
insmod -f /modules/usb-storage.ko
echo press any key when usb is done loading
read dummyvariable
/bin/busybox sh
set -x
ROOT=`cat /proc/cmdline | sed 's/.*root=// ; s/ .*//'`
echo seeking $ROOT
DESIRED=`echo $ROOT | sed -n 's/label\://p'`
if [ -n "$DESIRED" ] ; then
ROOT=
echo searching for volume with label $DESIRED
PARTS=`cat /proc/partitions | sed -n 's/.*sd/\/dev\/sd/p' | grep 'sd[a-z][1-9]'`
echo searchin in $PARTS
for i in $PARTS ; do
TEST=`dd if=$i bs=8 count=2 skip=143 2>/dev/null | \
sed -n "/^$DESIRED[^A-Za-z]*"'$/p'`
echo answer $TEST
if [ -n "$TEST" ] ; then
ROOT=$i
echo match $ROOT
# break
done
else
echo mount parition from command line is $ROOT
echo mount -t ext2 -o rw $ROOT /mnt
if [ $? -ne 0 ] ; then
/bin/busybox sh
umount /proc
if [ -n "$INIT" ]; then
exec switch_root /mnt $INIT </mnt/dev/console >/mnt/dev/console
else
exec switch_root /mnt $INIT </mnt/dev/null >/mnt/dev/null
else
exec switch_root /mnt /sbin/fastinit "$@" </mnt/dev/console >/mnt/dev/console
echo
echo Init Failed. Starting emergency shell....
/bin/busybox sh
/boot/grub/menu.list needs an option like this:title Experimental USB HDD boot root=label:USBSYSTEM
root (0x80,0)
kernel /boot/vmlinuz-2.6.21.4-eeepc rw vga=785 irqpoll i8042.noloop=1 root=label:USBSYSTEM
initrd /boot/initramfs-new.img
where initframfs-new.img is what I called my modified image (on real magnetic hard drive, I can keep a spare around since I am not short of space)
Edited by tuxpocket, 16 December 2007 - 12:24 AM.
Posted 16 December 2007 - 12:31 AM
gunzip -c initrd.gz | cpio -i
The ubuntu way of initrd is like this:
for x in $(cat /proc/cmdline); do
case $x in
init=*)
init=${x#init=}
root=*)
ROOT=${x#root=}
case $ROOT in
LABEL=*)
ROOT="/dev/disk/by-label/${ROOT#LABEL=}"
UUID=*)
ROOT="/dev/disk/by-uuid/${ROOT#UUID=}"
esac
But we'll need to get udev working first.
Posted 16 December 2007 - 06:37 AM
or the traditional
root=/dev/sdb1
Here is my init
I see that your init does not mount as unionfs, which I want to preserve. So I have taken your init and modify it.
For the unionfs, we also need to seek and mount the USER partition, which is a bit tricky as there is no way for grub to pass this parameter to init. So I just have it declared as "USER_USB" inside init. I also have to do the same for both /sbin/scanuser.sh and /sbin/formatuser.sh.
So here is the modified init for unionfs:
read dummyvariable
/bin/busybox sh
set -x
echo seeking $ROOT
ROOT=
echo searching in $PARTS
echo answer $TEST
ROOT=$i
echo match $ROOT
# break
done
else
echo mount partition from command line is $ROOT
echo mount -t ext2 -o ro $ROOT /mnt-system
/bin/busybox sh
if [ -n "$XANDROSSCAN" ]; then
exec switch_root /mnt-system /sbin/scanuser.sh
if [ -n "$XANDROSRESTORE" ]; then
exec switch_root /mnt-system /sbin/formatuser.sh
if [ -z "`grep nosplash /proc/cmdline`" ]; then
echo -n "[?25l"
cp /mnt-system/boot/startup.fb /dev/fb/0
USERPART=
echo seeking USER partition
DESIREDUSERPART="USER_USB"
echo searching for volume with label $DESIREDUSERPART
TESTUSERPART=`dd if=$i bs=8 count=2 skip=143 2>/dev/null | \
sed -n "/^$DESIREDUSERPART[^A-Za-z]*"'$/p'`
echo answer $TESTUSERPART
if [ -n "$TESTUSERPART" ] ; then
USERPART=$i
echo match $USERPART
# break
done
echo mount USER partition from command line is $USERPART
if ! mount -t ext3 -o rw $USERPART /mnt-user; then
echo Error mounting user partition. Must run filesystem scan!
# export USERPART
# Factory auto-format functionality
if [ -f /mnt-user/.autoformat ]; then
umount /mnt-user
exec switch_root /mnt-system /sbin/formatuser.sh -- --auto
#insmod /mnt-system/lib/modules/$VERSION/kernel/fs/unionfs/unionfs.ko > /dev/null
mount -t unionfs -o dirs=/mnt-user=rw:/mnt-system=ro unionfs /mnt
if [ $? -ne 0 ]; then
echo Could not mount unionfs. Starting debugging shell....
/bin/busybox sh
mount --move /mnt-system /mnt/mnt
umount -l /mnt-user
umount /proc
else
else
echo
/bin/busybox sh
Posted 16 December 2007 - 07:04 AM
When I was speaking of offering the user a menu, I meant a menu in the init script, not in grub.
The having to press return after the usb loads needs improvement. I think there is often a usb scan complete type entry that we could grep dmesg for in a loop with a 1 second sleep between checks. I know some people just put a fixed sleep in, but I figure there will be a day when it takes longer and my system won't boot. May just compile in the usb modules to solve that problem for good.
Getting udev going may be the better long range solution. But if I get this script cleaned up a little more, I think I may put it on the SSD so I can use that grub all the time even if I am going to boot linux off the external drive.
Edited by tuxpocket, 16 December 2007 - 07:05 AM.
Posted 16 December 2007 - 08:08 AM
Posted 16 December 2007 - 05:44 PM
#WARNING UNTESTED CODE
while [ -z `dmesg | grep 'usb-storage: device scan complete'` ] ; do
sleep .5
done
But I'd like to find a way for the user to interrupt the loop and go to busybox ifit fails.
On another topic, I think there would be a way to launch bash instead of /sbin/init to get a single user console mode with real tools, but I haven't made it work yet.
Edited by tuxpocket, 16 December 2007 - 05:45 PM.
Posted 06 January 2008 - 06:47 PM
For something stronger, most USB devices have unique serial numbers, so you can look those up too. I haven't found a tidy way to do it, but if you look at the "device" symlink itself you can tell what USB bus and target the device is using; then look in /proc/bus/usb/devices for the section with the right Bus and Dev#, and see if it lists a SerialNumber. If it does, I think it should be unique, so you could stamp it into your initrd when you create it and check for the device with a matching serial number on bootup.
I don't think this would work for SD cards though, as what you see on the USB bus is the cardreader, not the card itself. There may be some kind of serial number in the cards themselves but I doubt it. Your system of using volume labels is probably sufficient anyway, if the hard-coded offset is reliable.
Incidentally, it looks like Knoppix (or at least the version DSL is based on) just looks for any device with a KNOPPIX directory in its root - brute force and low tech, but it might be better than peeking into the partition without mounting it.
#12
Posted 11 January 2008 - 04:29 PM
Basically this init is achieved by combining the best of the volume label seeking method by tuxpocket and the init of the overlay filesystem method by Russell as per this thread. For this, we have to express our gratitude to both of them.
Here is my init, grub menu.lst, scanuser.sh and formatuser.sh:
init
ROOTLABEL=`cat /proc/cmdline | sed 's/.*root=label:// ; s/ .*//'`
USERLABEL=`cat /proc/cmdline | sed 's/.*USERLABEL:// ; s/ .*//'`
#VERSION=`cat /proc/version | cut -f3 -d" "`
ROOT=
USERPART=
#load usb modules
insmod -f /modules/usbcore.ko > /dev/null
insmod -f /modules/ehci-hcd.ko > /dev/null
insmod -f /modules/uhci-hcd.ko > /dev/null
insmod -f /modules/libusual.ko > /dev/null
insmod -f /modules/usb-storage.ko > /dev/null
/bin/busybox sh
set -x
# loop scan $ROOTLABEL in USB partitions
echo loop scan USB partition label:$ROOTLABEL
while
[ -z "$ROOT" ]
do
PARTS=`cat /proc/partitions | sed -n 's/.*sd/\/dev\/sd/p' | grep 'sd[a-z]'`
TEST=`dd if=$i bs=4 count=4 skip=286 2>/dev/null | \
sed -n "/^$ROOTLABEL[^A-Za-z]*"'$/p'`
ROOT=$i
done
sleep 1
done
echo mounting "$ROOT" as root partition
/bin/busybox sh
#mount USER partition in RAM disk
if [ $USERLABEL = "RAM" ]; then
mount -t tmpfs tmpfs /mnt-user
retval=$?
if [ $retval -ne 0 ]; then
echo Error mounting user partition in RAM disk.
echo Starting debugging shell....
/bin/busybox sh
else
# loop scan $USERLABEL in USB partitions
echo loop scan USB partition label:$USERLABEL
while
[ -z "$USERPART" ]
do
for j in $PARTS ; do
TEST=`dd if=$j bs=4 count=4 skip=286 2>/dev/null | \
sed -n "/^$USERLABEL[^A-Za-z]*"'$/p'`
USERPART=$j
done
sleep 1
done
echo -n "[?25l"
mount -t ext3 -o rw,noatime,nodiratime $USERPART /mnt-user
retval=$?
echo 'Error mounting user partition. Must run filesystem scan!'
umount /mnt-user
/bin/busybox sh
umount -l /mnt-user
umount /proc
else
else
echo
/bin/busybox sh
/boot/grub/menu.lst#
# Configured by Xandros Configuration system.
hiddenmenu
# default boot entry
default=0
# Boot automatically after 1 second.
timeout=0
# Fallback to Configure.
fallback=2
title Normal Boot (label:SYSTEM_USB / USER_USB)
root (hd0,0)
kernel /boot/vmlinuz-2.6.21.4-eeepc quiet rw vga=785 irqpoll root=label:SYSTEM_USB USERLABEL:USER_USB
initrd /boot/initramfs-usblabel-eeepc.img
title Perform Disk Scan (label:SYSTEM_USB / USER_USB)
root (hd0,0)
kernel /boot/vmlinuz-2.6.21.4-eeepc quiet rw vga=785 irqpoll USERLABEL:USER_USB root=label:SYSTEM_USB XANDROSSCAN=y
title Rescue Console
root (hd0,0)
kernel /boot/vmlinuz-2.6.21.4-eeepc quiet rw vga=785 irqpoll i8042.noloop=1 USERLABEL:USER_USB root=label:SYSTEM_USB XANDROSBOOTDEBUG=y
title Restore Factory Settings (label:SYSTEM_USB / USER_USB)
root (hd0,0)
kernel /boot/vmlinuz-2.6.21.4-eeepc quiet rw vga=normal nosplash=y irqpoll USERLABEL:USER_USB root=label:SYSTEM_USB XANDROSRESTORE=y
title Boot to RAM disk (label:SYSTEM_USB / RAM)
root (hd0,0)
kernel /boot/vmlinuz-2.6.21.4-eeepc quiet rw vga=785 irqpoll root=label:SYSTEM_USB USERLABEL:RAM
/sbin/scanuser.sh#!/bin/sh
clear
echo "Scanning user partition, please wait..."
mount -tproc proc /proc
USERPART=
echo seeking volume with label $USERLABEL
# echo answer $TEST
USERPART=$i
echo match in $USERPART
done
/sbin/fsck -C -f -y -text3 $USERPART
/sbin/tune2fs -j $USERPART
umount /proc
echo
echo "Press <ENTER> to reboot..."
read
/sbin/busybox.asus reboot -f
/sbin/formatuser.sh#!/bin/sh
clear
[ "$1" = "--auto" ] && AUTO=true
USERPART=
# echo answer $TEST
USERPART=$i
done
echo You are about to restore this unit to factory settings.
echo All user data will be lost!
echo format USER partition label:$USERLABEL $USERPART
echo Are you sure?
echo -n "Enter 'yes' to continue: "
read INPUT
if [ "$INPUT" != "yes" ]; then
if [ -n $AUTO ]; then
mount $USERPART /mnt
rm -f /mnt/.autoformat
umount /mnt
umount /proc
echo -n "Formatting user partition, please wait... "
/sbin/mkfs.ext3 -q -L $USERLABEL $USERPART
echo "done!"
echo
if [ -z $AUTO ]; then
umount /proc
read
else
echo "Press <ENTER> to shutdown..."
read
echo 5 > /proc/acpi/sleep
Actually, I am thinking we should be able to make scanuser.sh and formatuser.sh simpler by passing arguments from init. This I will look into later.Finally, the SYSTEM and USER partition do not need to be on the same disk. For example, if you give a root label:SYSTEM, and user label:USER in grub menu.lst, this will just mount the original Xandros in the SSD!
Also, I have added the F9 option to mount the unionfs in RAM disk. This will be useful for doing backup and repair, etc on the USER partition.
Edited by albkwan, 12 January 2008 - 01:41 AM.
#13
Posted 11 January 2008 - 04:33 PM
Edited by tuxpocket, 11 January 2008 - 04:34 PM.
#14
Posted 12 January 2008 - 02:38 AM
#15
Posted 12 January 2008 - 04:47 AM
if you take a look at the initramfs at http://slofith.org/p...eeepc/initramfs you'll see I'm using /mnt-system/sbin/cryptsetup to do encrypted overlay, but the same works for any executable. ld-linux.so.2 and libc.so.6 are the required base, and you can run "ldd /sbin/whatever" to see what libraries any specific utility needs (ignore "linux-gate.so.1" though, it's kernel internal)
Edited by russm, 12 January 2008 - 04:48 AM.
#16
Posted 12 January 2008 - 05:01 AM
A side note dd hexdump is fine for ext filesystems, but its a pain for fat which stores its (tiny) uuid chars in reverse. Course then again you could also just have it match the reverse.
4G White 701a with Flash PCI-E Slot | 2 gig Ram | Gentoo | Kernel 2.6.25.4
#17
Posted 12 January 2008 - 05:22 AM
What library we need to run chmod in the initramfs? I have tried to create .firstrundone as per your init but the system is complaining command chown not found.
albkwan
#18
Posted 12 January 2008 - 05:27 AM
Yes, that dd incantation is limited to ext2/3. But then it's looking for a linux system volume, and that's unlikely to still be minix or xfs, so... (well it could be reiserfs I guess)
If someone can come up with a cleaner means of detecting the desired partition using only built in tools, or a *small* stand alone executable I'm all ears. Even getting that version of busybox to run an external executable was proving quite troublesome though... tried setting up uclibc... ironically some of these things are easier to get going on non-x86 embedded linux platforms.
Edited by tuxpocket, 12 January 2008 - 05:29 AM.
#19
Posted 12 January 2008 - 05:43 AM
russm@nestor:/var/local/md1/russm/software/EeePC/initramfs/unpacked$ ls -lF total 44 drwxr-xr-x 2 russm russm 4096 2008-01-12 15:32 bin/ drwxr-xr-x 3 russm russm 4096 2008-01-12 15:32 dev/ drwxr-xr-x 2 russm russm 4096 2008-01-12 15:32 etc/ -rwxr-xr-x 1 russm russm 2555 2008-01-12 15:32 init* drwxr-xr-x 2 russm russm 4096 2008-01-12 15:32 lib/ drwxr-xr-x 2 russm russm 4096 2008-01-12 15:32 mnt/ drwxr-xr-x 2 russm russm 4096 2008-01-12 15:32 mnt-system/ drwxr-xr-x 2 russm russm 4096 2008-01-12 15:32 mnt-user/ drwxr-xr-x 2 russm russm 4096 2008-01-12 15:32 modules/ drwxr-xr-x 2 russm russm 4096 2008-01-12 15:32 proc/ drwxr-xr-x 2 russm russm 4096 2008-01-12 15:32 sys/ russm@nestor:/var/local/md1/russm/software/EeePC/initramfs/unpacked$ ls -lF lib/ total 0 lrwxrwxrwx 1 russm russm 29 2008-01-12 15:32 ld-linux.so.2 -> /mnt-system/lib/ld-linux.so.2 lrwxrwxrwx 1 russm russm 25 2008-01-12 15:32 libc.so.6 -> /mnt-system/lib/libc.so.6 lrwxrwxrwx 1 russm russm 36 2008-01-12 15:32 libdevmapper.so.1.02 -> /mnt-system/lib/libdevmapper.so.1.02 lrwxrwxrwx 1 russm russm 26 2008-01-12 15:32 libdl.so.2 -> /mnt-system/lib/libdl.so.2 lrwxrwxrwx 1 russm russm 28 2008-01-12 15:32 libpopt.so.0 -> /mnt-system/lib/libpopt.so.0 lrwxrwxrwx 1 russm russm 31 2008-01-12 15:32 libselinux.so.1 -> /mnt-system/lib/libselinux.so.1 lrwxrwxrwx 1 russm russm 29 2008-01-12 15:32 libsepol.so.1 -> /mnt-system/lib/libsepol.so.1 lrwxrwxrwx 1 russm russm 28 2008-01-12 15:32 libuuid.so.1 -> /mnt-system/lib/libuuid.so.1 russm@nestor:/var/local/md1/russm/software/EeePC/initramfs/unpacked$if you're getting "error while loading shared libraries" and "cannot open shared object file" then the glibc runtime is at least minimally working and you just need to link whatever library it's complaining about into the initramfs's /lib directory.
#20
Posted 12 January 2008 - 05:46 AM
