Webcam no longer works
6 replies to this topic
#1 bobm
  • 6 posts
Posted 12 December 2007 - 04:52 AM
Bummer, I did a restore to the default OS and since then the webcam has stopped working.
Interestingly the BIOS had the webcam disabled so I enabled it.
But the system diags don't see the camera and the webcam app just gives me a blank screen, although the webcam app does turn on the green led.
the app eeecamtray seg faults for me and doing:
echo 1 > /proc/acpi/asus/camera
doesn't change a thing.
Any suggestions out there?
I'm going to put the old 512M stick back in and see if that changes anything. (doubtful)
thx in advance..
#2 tuxpocket
  • 496 posts
Posted 12 December 2007 - 04:54 AM
set bios to os install finished
#3 bobm
  • 6 posts
Posted 12 December 2007 - 04:58 AM
Thanks Tuxpocket, that did it..
and in record time..
I'll update the wiki to reflect this issue (non-issue)
#4 AgentEntropy
  • 63 posts
Posted 12 December 2007 - 06:42 PM
This is a known issue. Further discussion can be found here: http://forum.eeeuser...pic.php?id=1455
Please use the search before posting new topics. Thank you. :)
#5 bobm
  • 6 posts
Posted 13 December 2007 - 06:31 AM
Oh but I did use the search, quite extensively.
it's not in the wiki and searching for 'dead webcam', 'inactive webcam', even 'webcam' didn't turn up anything.
I didn't think to search on 'webcam black image' which gets to the discussion. Note that I was using the diagnostics to determine that the webcam was not working...
Thanks for the help..
#6 vwra
  • 8 posts
Posted 12 March 2008 - 04:27 PM
I have a USB WebCam that lists correctly when I run Diagnostics > USB > Test as "VIMICRO Corp PCam". Is there a way to activate this external web cam for use with Skype or reording video application ?
ADDED: I also tried my Creative Optia and it also shows up correctly in Diagnostics but no connect in Skype or recording application. ????
Edited by vwra, 30 March 2008 - 05:19 PM.
#7 harlequin93
  • 5 posts
Posted 27 November 2009 - 12:15 AM
I also have an external USB webcam that lists correctly in Diagnostics > USB > Test, but Skype reports "No devices found."
Do I need to enable this device? And where do I enable it?
Edited by harlequin93, 27 November 2009 - 12:17 AM.
