Password Manager?
Posted 09 December 2007 - 09:07 PM
I saw there is a java-based one, but I really need a more complete one such as Keepass, etc.
Any suggestions/help? I don't know where else to look. :(
Posted 09 December 2007 - 11:03 PM
Posted 09 December 2007 - 11:24 PM
You keep believing, I'll keep evolving. Anon
Posted 09 December 2007 - 11:53 PM
KeePassX (which has a native Linux version) and Revelation also didn't seem to work properly....
On the other hand, gpass works, although it seems quite basic.
Edited by mkrishnan, 09 December 2007 - 11:57 PM.
Posted 10 December 2007 - 02:03 AM
After installing wine, I copied the KeePass folder from a USB drive that I had installed it on, into the My Documents folder on my Eee.
To run the program, open the terminal and then type:
wine "z:\home\user\My Documents\KeePassPortable\KeePassPortable.exe"
Now, that's a lot to type, so an alternative is to double click on the KeePassPortable.exe file. Then, when it asks you what application to open the file with, choose wine at usr/lib/wine/wine.bin.
To automate things even further, I created an entry to my Start Menu (Easy Mode) using IceMC, so I can start the program with a simple click. You can simply type the above command (wine "z:.....") into the Exec field for the menu item you've created.
Edited by catlike, 10 December 2007 - 02:04 AM.
Posted 25 December 2007 - 03:56 AM
A few things to note:
1) Download the .deb not the binary, as the binary (standalone package) doesn't seem to work.
2) After installing, you'll need to apt-get libpng3 which requires the extra xandros repositries.
3) When you first run keepass, it will probably segfault, you'll need to restart the 3epc and then it should run perfectly. This seems to happen with quite a lot of programs. You might think its not working, but if you restart you find it works fine.
And the final result, keepass running natively on linux without any emulation or other worries.
Posted 25 December 2007 - 06:02 AM
Posted 25 December 2007 - 07:22 AM
Posted 25 December 2007 - 07:43 PM
Posted 26 December 2007 - 12:00 AM
If you're using the default xandros simple gui. You can use this utility to add an icon into one of your tabs.
Posted 26 December 2007 - 12:43 AM
#12
Posted 26 December 2007 - 10:35 AM
/home/user> whereis keepass keepass: /usr/local/bin/keepass
#13
Posted 26 December 2007 - 02:44 PM
#14
Posted 26 December 2007 - 04:34 PM
#15
Posted 26 December 2007 - 04:48 PM
#16
Posted 26 December 2007 - 06:35 PM
it's from semanticgap.com.
#17
Posted 26 December 2007 - 06:55 PM
#18
Posted 27 December 2007 - 06:14 AM
#19
Posted 04 January 2008 - 05:45 PM
#20
Posted 04 January 2008 - 05:48 PM
