Atheros updates drivers for eee
Posted 01 December 2007 - 06:20 PM
http://madwifi.org/ticket/1679
These are the most direct directions: http://madwifi.org/t...192#comment:186
It takes about 5 minutes :).
Posted 01 December 2007 - 06:32 PM
Posted 01 December 2007 - 06:36 PM
Those should be as "cut and paste" friendly as possible.
Note: the native drivers solved the issue for me where ndiswrapper was using 50% of the cpu. Eliminating ndiswrapper eliminated the resource leak.
Posted 01 December 2007 - 07:23 PM
Posted 01 December 2007 - 07:31 PM
is that working well for you guys?
they aren't working for me... I m using Xubuntu Gutsy
Edited by kiddyfurby, 04 December 2007 - 03:09 AM.
Posted 01 December 2007 - 07:58 PM
Posted 01 December 2007 - 08:03 PM
sudo apt-get remove ndiswrapper-common ndiswrapper-utils-1.9
removed the blacklist file, then reebooted
and in Network Connection applet changed to wlan0 and it worked as charm ;)
Posted 01 December 2007 - 08:06 PM
Posted 01 December 2007 - 08:12 PM
Posted 01 December 2007 - 08:23 PM
Posted 01 December 2007 - 08:24 PM
#12
Posted 01 December 2007 - 09:33 PM
#13
Posted 01 December 2007 - 09:57 PM
#14
Posted 01 December 2007 - 10:46 PM
#15
Posted 01 December 2007 - 10:58 PM
#16
Posted 01 December 2007 - 11:58 PM
#17
Posted 02 December 2007 - 12:18 AM
I could either get the 5-bar wifi hotspot finder in the taskbar on top, or I could get it so that it was in /etc/network/interfaces, but I couldn't get _both_. Eventually I got it so that it was just magically "working" and pinging my router, but no 5-bar display up top. I had some trouble with the atl2 driver spontaneously deciding to not see the switch, though, so I had done some poking around with modules prior to patching madwifi..
#18
Posted 02 December 2007 - 12:32 AM
#19
Posted 02 December 2007 - 01:05 AM
#20
Posted 02 December 2007 - 01:22 AM
