OS claiming "no space left on device" when df -h shows over 600M free?
Posted 02 June 2008 - 01:42 AM
I've had some major troubles with my little EEE's filesystem in the past few days, have searched the forums quite a bit but haven't found an answer to the problem yet.
I think my long-term strategy is to remove the unionfs and go with straight ext2, but it's the last week of Uni this week so if possible would love to find a "quick fix" until I have time to do a proper upgrade in the holidays!
The sympoms are these: a few days ago, I booted my EEE-PC and things like Wireless failed to start and gave error messages. Investigating in the terminal I find the cause seems to be "no space left on device", e.g. trying "/etc/init.d/networking restart" eventually fails with a message "cannot touch '/etc/hosts.new': No space left on device".
THis is happening despite the output of df -h which is:
Filesystem Size Used Avail Use% Mounted on
rootfs 1.4G 727M 623M 54% /
/dev/sda1 1.4G 727M 623M 54% /
unionfs 1.4G 727M 623M 54% /
tmpfs 249M 4.0K 249M 1% /dev/shm
tmpfs 128M 12K 128M 1% /tmp
/dev/sdhc1 7.5G 707M 6.5G 10% /home/user/homeSDHC
/dev/sdc1 3.9G 215M 3.6G 6% /media/Cruzer Crossfire
and typing mount gives the following which looks pretty normal:
rootfs on / type rootfs (rw)
/dev/sda1 on / type ext2 (ro)
unionfs on / type unionfs (rw,dirs=/=rw:/=ro)
proc on /proc type proc (rw)
sysfs on /sys type sysfs (rw)
devpts on /dev/pts type devpts (rw)
tmpfs on /dev/shm type tmpfs (rw)
tmpfs on /tmp type tmpfs (rw)
usbfs on /proc/bus/usb type usbfs (rw)
/dev/sdhc1 on /home/user/homeSDHC type ext2 (rw)
/dev/sdc1 on /media/Cruzer Crossfire type vfat (rw,fmask=0022,dmask=0022,codepage=cp850,iocharset=iso8859-1)
I recently tried booting up using a "TRK rescue" Linux boot USB disk I created a while back, and deleting some non-essential files off the "protected" HDD (eg /usr/share/games), but it didn't seem to help.
Any ideas/help greatly appreciated! ;)
Posted 03 June 2008 - 04:31 AM
I've just had a similar problem. For me it turned out to be the iNodes.... do 'df -i' and see if you have zero or low number of IFree. I was on between zero and 20. I found out lots of zero size .wh.? files are created when you delete things for UnionFS I think. I ended up doing what you did and booting off of Parted Magic and deleted some .wh files as it was too unstable to use file manager (9000 in my opera cache directory).... still in the process of deleting now but running a lot smoother.
Hope this helps ... oh i did a 'ls -alR |more' to give me some idea where there was lots of similar files.
Edited by M1ster_Happy, 03 June 2008 - 05:50 AM.
Posted 04 June 2008 - 12:49 AM
Surprising that more people haven't run into this problem?? Maybe we should create a Wiki entry.
Oh well, it's great to be up & running again, & reinforces my plan to get rid of unionfs when I have more tinkering time.
Posted 04 June 2008 - 02:35 AM
To be honest I wouldn't want to recommend it in a wiki as I'm a total linux newbie so it may turn out to be wrong! (I hope not) For now if you can change the thread name you could prefix SOLVED on it, just an idea.
I'm not really sure why they get created as they seem to be a 'white out' file to hide the deleted file on the lower partition of the unionfs set up... but they get created in directories that don't exist on the lower partition, and in directories that have '.wh.__dir_opaque' files which is suggesting lower partition directories to be ignored anyway (so i've read.. maybe wrong! ). I'm sure there's some logic to it but the way it seems it should be fine to delete any '.wh.*' files where a '.wh.__dir_opaque' file exists (not deleting the opaque), and where the lower partitions directory is empty or does not exist. I think you have to watch out for deleting a deleted directory file as well which is 'hiding' the directory in existence on the lower partition (don't think its too much of a problem as it will just be visible again).
I'd like to write a script to do it but like you I don't believe I need the unionfs system so I think I will just remove it.... but until then it seems deleting them will keep us going. Like you said you would think more people would have the same issue... but then alot of mine were opera so i guess I wouldn't have hit the issue for a while longer... guess we'll see.
Let me know if you get any issues.
Posted 04 June 2008 - 03:05 PM
/home/user> df -h Filesystem Size Used Avail Use% Mounted on rootfs 1.4G 452M 898M 34% / /dev/sda1 1.4G 452M 898M 34% / unionfs 1.4G 452M 898M 34% / tmpfs 443M 16K 443M 1% /dev/shm tmpfs 128M 56K 128M 1% /tmpWhile diskutil shows use 451MB (31.76%) and available 969MB (68.24%)...
Is there anything I can do?
btw
/home/user> df -i Filesystem Inodes IUsed IFree IUse% Mounted on rootfs 185088 47945 137143 26% / /dev/sda1 185088 47945 137143 26% / unionfs 185088 47945 137143 26% / tmpfs 113339 10 113329 1% /dev/shm tmpfs 113339 47 113292 1% /tmp
Linux: stable, secure, clean and does not fragment.
Linux user 474613, Machine 382238/9
AMD Geode 500MHz: "It will perform like a one-legged dog with arthritis, unless you run something very light like DSL." by bolomkxxviii
Posted 04 June 2008 - 09:55 PM
I think you may have a different issue. Are you getting errors specifically suggesting you have a lack of space?
Our problem was we had few or no iNodes left which meant files could not be created even zero size ones. Your iNode count is fine specifically iFree.
Posted 30 June 2008 - 06:25 PM
The method is inspired by this thread, and consists of simply mounting /dev/sda2 in a temp location (like, say, /mnt/sda2), and doing a simple find /temp/location -iname '.wh*' -delete.
Easy-to-follow steps (as commands)
$ su [enter password at prompt] # mkdir -pv /mnt/sda2 # mount /dev/sda2 /mnt/sda2 # find /mnt/sda2 -iname '.wh*' -delete [wait a long-ish while, then check your new IFree count:] # du -i [don't forget to clean up:] # umount /dev/sda2 # exitUPDATE 2008-07-10: The mount command was missing from this list of commands! This has been corrected now.
I went from ~500-ish free inodes to well over 100k, so...
Methinks a tool to do this should be run periodically -- how quickly the inode table gets filled up seems to depend on how much you use the Eee (assuming the .wh files have something to do with deleting/deleted files, which would make sense as they seem to appear primarily in cache dirs), but it does seem inevitable.
Edited by Narc, 10 July 2008 - 12:36 PM.
Posted 30 June 2008 - 06:58 PM
If you make this as a script could you set up a cron job? (I haven't looked at cron on the Eee, but I know it's installed.)
Edited by SteveLawUK, 30 June 2008 - 06:59 PM.
If it ain't broke, don't fix it.
Posted 30 June 2008 - 07:14 PM
#!/bin/bash # Create directory if needed (never hurts) sudo mkdir -pv /mnt/sda2 # Mount /dev/sda2 into our new directory sudo mount /dev/sda2 /mnt/sda2 # Delete the stupid .wh* files sudo find /mnt/sda2 -iname '.wh*' -delete # Don't forget to clean up sudo umount /dev/sda2UPDATE 2008-07-10: The mount command was missing in the previous version of this script! It has now been corrected.
Paste that into a new file, chmod a+x it, then run 'crontab -e' and add this line:
<MIN> <HOUR> <DAY> <MONTH> <DAYOFWEEK> /path/to/cleanup-script-- replacing:
- <MIN> with a number for the minute the cron job should run (e.g. 17)
- <HOUR> with a number for the hour, or * (asterisk) to run hourly
- <DAY> with a number for the day or * to run daily
- <MONTH> with a number for the month or * to run monthly
- <DAYOFWEEK> with 1-7 representing Mon-Sun or * to run daily
- /path/to/cleanup-script with the path to the script you've created (of course)
By my approximation, running it daily should fix the problem forever, so here's how it would look for running daily at 11:53 am:
53 11 * * * /path/to/the-scriptHope that helps!
ETA: Rant: Considering that, for most applications, you should reach the disk space limit long before the inode limit, and that this whole problem has arisen because of the way the stock Xandros is set up (with UnionFS), this script, or something like it, should have come with the stock install. But, ah, well, at least it gives us geek-types something to fix, yeah? :)
ETA2: Oh, and cron doesn't seem to be set up to run automatically (at least not on my Eee), so you'll need to set that up, too, somewhere. If you wanted to go the crontab way. Probably easier to just save the script and run it whenever the problem shows up (which should be pretty rarely).
Edited by Narc, 10 July 2008 - 12:35 PM.
Posted 30 June 2008 - 10:36 PM
Is it ok to delete all of the .wh files, will any of them be needed? I know most of them are not but they do serve a purpose and I'm wondering if some might actually be valid.
And thanks for the script.
Posted 01 July 2008 - 03:47 AM
Just another comment - I had so many .wh files in the /var/tmp directory, I couldn't just rm ".wh*" because there were so many, it seemed to cause shell commands to fall over! So I had to delete one letter at a time, and ended up writing a little script to do that.
Not sure if "find" is more robust though and able to handle massive numbers of files at once - and anyway, I guess if you ran a cron job as you're suggesting, you'd never build up too many of them at once anyway.
#12
Posted 01 July 2008 - 06:30 AM
#13
Posted 04 July 2008 - 03:29 AM
#14
Posted 04 July 2008 - 07:02 AM
On my Eee, the F9 menu includes a "Check for errors" entry; if your model does also, try running it, to see if it fixes anything.
Also, can you go to a terminal, run "mount", and copy/paste the output here?
#15
Posted 06 July 2008 - 12:13 AM
Here's the output after I run "mount" in terminal
/dev/sdb1 on /media/MMC-SD/partition1 type vfat (rw,nosuid,nodev,noexec,fmask=0111,dmask=0000,codepage=cp850,iocharset=utf8,shortname=mixed)
Hey, if nothing else I just learned how to copy/paste out of terminal anyway, but ya, let me know if this gives you any ideas.
#16
Posted 10 July 2008 - 11:43 AM
The script above does not have a mount in it, only a mkdir, then a find on an empty folder... this obviously does not work.
The f9 busybox console does not have find, so I can't do it there either.
#17
Posted 10 July 2008 - 12:33 PM
#!/bin/bash # Create directory if needed (never hurts) sudo mkdir -pv /mnt/sda2 # Mount /dev/sda2 into our new directory sudo mount /dev/sda2 /mnt/sda2 # Delete the stupid .wh* files sudo find /mnt/sda2 -iname '.wh*' -delete # Don't forget to clean up sudo umount /dev/sda2I'll correct it in the earlier post, too.
#18
Posted 10 July 2008 - 12:49 PM
#19
Posted 10 July 2008 - 12:57 PM
Also, with regards to the missing crontab thing - you can call the script from /usr/sbin/services.sh - then it'll get run on every bootup :)
#20
Posted 10 July 2008 - 05:57 PM
I ended up incorporating beckylou's /tmp solution into Narc's commands and so I ran
sudo mkdir -pv /tmp/sda2
sudo mount /dev/sda2 /tmp/sda2
sudo find /tmp/sda2 -iname '.wh*' -delete
which left me with only 1314 used inodes
Honestly I can't say I understand any of it, so I don't know what the last command accomplishes for me, if anything. I'll have to make an effort to read up on mounting. If anyone comes up with a detailed description for writing and incorporating a little program that runs automatically every week I would be ecstatic. If not I'll see if I can't make one myself, I know all the real info is already in this thread. Thanks a lot for the help all, no more unwanted F9 reinstalls! Free inodes for all!
