battery percent stuck at 20
19 replies to this topic
#1 ryanbk
  • 36 posts
Posted 21 November 2007 - 12:48 AM
I have xp on my black eee pc and my battery percentage is stuck at 20%. Is there any reason it refuses to report the correct %?
#2 ryanbk
  • 36 posts
Posted 21 November 2007 - 03:08 AM
update:
I left the machine plugged in for about 3 hrs and tried running on battery for a while. I only got about 30 min of usage out of it! any idea whats going on?
#3 mrdan
  • 43 posts
Posted 21 November 2007 - 03:10 AM
Did you install the ASUS ACPI driver?
#4 ryanbk
  • 36 posts
Posted 21 November 2007 - 03:47 AM
I believe so, and I even did a repair install for good measure. I also verified all drivers were installed in Dev manager and nothing seemed out of the ordinary. Any other ideas to help me out? thanks
#5 mrdan
  • 43 posts
Posted 21 November 2007 - 04:10 AM
Double click the taskbar battery icon.
Then click on the battery in the square under the #1.
What does the battery status read?
#6 ryanbk
  • 36 posts
Posted 21 November 2007 - 04:19 AM
Posted Image
It was 40% with the ac plugged in then it dropped to 30% just a few minutes after I unplugged it...any help? thanks again
#7 mrdan
  • 43 posts
Posted 21 November 2007 - 04:27 AM
Wait, I thought it was stuck at 20%?
#8 ryanbk
  • 36 posts
Posted 21 November 2007 - 04:30 AM
it was for the longest time until i rebooted. since then its been going back and forth between 30 and 40 as i alternate the power sources. so weird.
#9 mrdan
  • 43 posts
Posted 21 November 2007 - 05:00 AM
Go into Device Manager and expand the 'System devices' driver tree. Do you see 'ASUS ACPI Driver'?
#10 ryanbk
  • 36 posts
Posted 21 November 2007 - 05:05 AM
Yep it shows as though it's installed. BTW the battery is now jumping from 20 to 30 and back randomly.
Posted Image
#11 mrdan
  • 43 posts
Posted 21 November 2007 - 05:07 AM
Sounds like a bad battery or bad charger. Contact an ASUS for warranty replacement. Hopefully you won't have to send the whole machine in, as I'm sure you have spent plenty of time getting it configured for XP.
#12 Iwanteee07
  • 42 posts
Posted 21 November 2007 - 06:47 AM
the battery indicator is not always correct on XP. try charing the EEE until the battery light goes off. then restart, it should show 100%. When you are charging, the battery indicator will not go up until you restart the computer. Also, it might only display an approximate charge, that might explain the back and forth 20 - 30 %. I think of it as the way that it is include in the original OS (cannot see % or bars when plugged in), when unplug it goes about 90 80 70 60 50 30 20 10%.
Anyhow, i hope this is helpful.
#13 ryanbk
  • 36 posts
Posted 21 November 2007 - 04:55 PM
how long does a typical charge take? because i had this thing plugged in for hours yesterday then attempted to use it on battery mode and only got maybe 30min of batter use from it...
#14 Iwanteee07
  • 42 posts
Posted 22 November 2007 - 02:11 AM
It depends, If you turn the EEE off, you should be able to have a full charge around 3 hours. But if you use it while plugged in, it will take a LONG time.
#15 sillyrabbitt123
  • 198 posts
Posted 26 November 2007 - 02:21 AM
I just noticed I am having the same problem here as well! stuck at 30% i have XP on the eee as well :(
i will charge it while its off and then start it up hopefully it goes back to 100%
#16 ryanbk
  • 36 posts
Posted 26 November 2007 - 02:56 AM
mine ended up being fine, yours probably is also. it takes a LONG time to charge if ur using the pc while its plugged in, and maybe 3hr while its shut down. asus says the indicator is only a rough estmate for battery percentage.
#17 sillyrabbitt123
  • 198 posts
Posted 26 November 2007 - 03:01 AM
thanks buddy! i will leave it charging all night and see. i will post back.
thanks
#18 sillyrabbitt123
  • 198 posts
Posted 26 November 2007 - 01:03 PM
yup a nice long charge overnight brought it back to 100%. i hope it stays!
#19 paQ
  • 18 posts
Posted 28 December 2007 - 10:22 PM
Mine is stuck now too
at 20
but it wasn;t earlier when installing (without charger)
I feel (could be wrong though) that whe the machine is hot (and the fan is on)
it hardly charges at all!
When the EEE is still cool the first one and a half hour or so, it charges more rapidly.
#20 Bremen
  • 543 posts
  • LocationTexas
Posted 28 December 2007 - 11:35 PM
The little power supply can barely keep up when you are using your E while it is plugged in. So yes, it can take a looooong time to charge. Give it a few hours charging while turned off and it should charge normally. The charger has low amperage.
iPad :)
Gateway LT2104u - 2 gig ram
Windows 7 Starter
