what else for the chart (of linux distributions)?
Posted 24 March 2008 - 03:01 AM
http://shengchieh.50...m/overview.html
Beside
- status as of
- version
- ethernet
- wireless
- camera
- acpi
- installation type
- need to partition before installtion
- other comments
What other columns should I have. Also, if you have any comment about the columns I already have, please comment.
Do >>>NOT<<< tell me what works for a certain distribution. I am NOT interested in filling the chart - you folks will do that - just interested in designing the
table so that it'll go on the wiki, and then, everybody can fill in. So comment on just the chart features.
Sheng-Chieh
http://shengchieh.50.../tuxslinks.html
Posted 24 March 2008 - 04:09 AM
- kernel version
- boot speed
- memory taken by the install
- disk space taken by the install
- graphics - resolution and 3D support
- window scaling for 800x480
- default desktop/window manager
All above assumes non modified fresh install.
Edited by klopus, 24 March 2008 - 04:10 AM.
Black EeePC 701 4G, 1GB RAM. Xandros Advanced Mode on SSD
Posted 24 March 2008 - 05:34 AM
Dumb question: what is OTOB?
Sheng-Chieh
Posted 24 March 2008 - 05:42 AM
Posted 25 March 2008 - 12:49 AM
- kernel version
- boot speed
on how to find them. So far I have
-* Please the status date if you modify anything.
- Leave a question mark if you can't figure out what to say.
- ACPI = Advanced Configuration and Power Interface. Test Fn-F1, Fn-F2,...,Fn-F9.
- Bootup Time = time between starting the machine to then login screen. Turn off auto-login if needed.
- To find the kernel version, type "uname -a".
- To find the disk usage, type "df".
So
1) how do one find the memory usage?
2) how do one find about the graphics support?
3) how can one tell if the distro has 800x480 window scaling?
Sheng-Chieh
Posted 25 March 2008 - 01:10 AM
3) I'm not sure if this is what is meant, but it would be good to know if the OS will come up in 800x480 automatically or will come up in some other resolution (640x480) and need modifications.
Also:
- It's mainly historical, since Xandros is probably the only distribution that has this issue, but support for >1GB of RAM should probably be on the list.
- Going along with the OOTB idea... It might be nice if some of these boxes had, rather than just yes/no, perhaps three settings, e.g. like "-" or NA (not available), "S" (standard), and "O" (optional, meaning it can be done but does not work OOTB).
- For ACPI... perhaps split this into: (a) support for onscreen displays for the Fn keys, (b) functional power management (suspend, power off, etc), © support for overclocking, and (d) fan control, although probably no distro would have (d) as a standard.
- SDHC reader support (I think there may be some that have issues with this, although the majors all seem to handle the SDHC as well as it can be handled?) -- this is support for it as a hotplug / removable device, not as a boot device (since if you boot off the SDHC, it's provided to the OS on a platter by BIOS).
Posted 25 March 2008 - 04:57 PM
I tell which one the eee is using?
Sheng-Chieh
Posted 25 March 2008 - 05:38 PM
What is missing is direction for gathering more ACPI informations and window display usage. I lumped USB and SD infos in "other comments"
since not all distributions have those issues.
Any more comments before I throw this on the eee wiki?
Sheng-Chieh
Posted 25 March 2008 - 06:32 PM
Posted 13 April 2008 - 12:24 PM
Which filesystem do you use? which services do you load? etc...
Also, what good is it to measure till the login screen when you can login at some distributions and have an instant desktop while others start loading stuff again.
With regards to memory, it also doesn't make much sense to measure memory "footprint". If an application uses memory, it's because it needs memory. You want it to use that memory because it's faster that way. Unused memory is wasted memory.
On the other hand, if you don't have enough memory to cater your needs, you might want to choose different apps.
again, it's distribution independent.
Same goes actually, for the disk-space usage. It's the applications, not the distribution.
Posted 13 April 2008 - 03:10 PM
#12
Posted 13 April 2008 - 04:50 PM
However, the resulting values still won't tell you much. I agree, many ppl like to judge on the first impression, but frankly, that's just a bad judgement. If solution a runs mediocre and solution b is horrible (ootb) but with with a little bit of tewaking it's perfect, I think solution b is preferable. And honestly, I don't know why so many people complain that they have to adjust some settings after the initial OS installation, windows is not usable at all ootb.
First, it's not very reasonable to run a distribution out of the box.
It's VERY likely that you have some services running which you don't need at all, while it's quite possible that some other stuff you'd like to have is missing. Same goes for programs.
Also, do you have the programs preleoded at startup or are they loaded when you actually need them? It only makes a difference in terms of _when_ you have to wait, but it's very hard to measure.
Second, some distributions give many different installation options, some give none. Some install what they think you need, some ask for what you need. Of course, you can compare all distributions installed with default options, but it makes no sense to install everything default, especially on something like the eee.
And btw, also my default xandros does not start in 10 seconds, more like 30.
Anyways, for what it's worth, here are my settings:
Distribution: Gentoo
Kernel: 2.6.24-r4-gentoo + eee-patches
all hardware works (3d+webcam is not yet tested)
Filesystem: reiserfs
Install type: default install following the gentoo handbook. Compiled on another machine and then copied to the eee.
Need to partition before installation: is part of the installation process.
Window Manager: Fluxbox
Ease of Use: very easy - easy
Ease of Administration: advanced - difficult
Bootup speed: ca.50 sec (the dongest delay is due to mounting the disk and bringing up the network+ip)
Total size of install: 1.4gig
Total memory used after Fluxbox is started: 73MB
Time needed for installation+configuration: a weekend
installed programs:
a bunch of system tools + all needed hardware drivers
vim+gvim+cream (text-editing)
kile (latex)
elinks (webbrowser)
konqueror (web+filebrowser)
krusader (filebrowser)
sylpeed-claws (mail)
mplayer + vlc + xine (videoplayer)
irssi (irc-client)
Xorg 1.4 (x-server)
fluxbox (window manager)
urxvt (terminal)
skype
amarok
#13
Posted 13 April 2008 - 08:00 PM
So all this goes to the point that main distro differentiation is how it's OTOB on Eee. This comes as quantitative (footprint) and qualitative - does it support Eee hardware OTOB or one has to muck around, search all over and spend time trying to make basic things like WiFi and ACPI work, basic dialogs to scale to 800x480 and to repeat all that cra*p all over again when kernel or something else gets updated. In qualitative category Mandriva 2008.1 is a king since it comes officially with Eee support out of the box and it's guaranteed not to break on upstream updates. But like Ubuntu it's a resource and boot time pig right out of the box.
Edited by klopus, 13 April 2008 - 08:09 PM.
#14
Posted 13 April 2008 - 08:54 PM
That's why I say it's pointless to compare them out of the box.
For that you'd need a distribution which was made for the eee and that is only the default xandros.
#15
Posted 13 April 2008 - 09:06 PM
#16
Posted 13 April 2008 - 11:50 PM
I'll just add a few remarks to say that (in principle) it's easier to remove packages that you don't need from a full-featured distribution like Mandriva, Ubuntu, SuSE, Fedora, etc, than to add packages to a mini-distribution - specially if you have to manually compile these packages from source.
The disk space problem will become much less relevant as soon as the 900 is out, with 20GB vs. 4GB SSD which is what most of us have now. And most dialog windows that right now we have to alt-move around, will fit on the 1024x600 screen.
Finally, my everything-including-the-kitchen-sink Mandriva 2008.1 (I even have KDevelop on it, for heaven's sake!) compressed is 2GB and runs fine from my 8GB SDHC card, and Gaijin has reported that KDE4 + Compiz runs perfectly well on his non-overclocked 701.
My point is we shouldn't worry so much about cutting down on features of Linux distributions as the eeePC will work fine even with the most full-featured ones, with more or less tinkering required depending on the distribution chosen.
Mandriva and Ubuntu pre-installed SDHC cards for the eeePC - eeePCLinux.com
"Because Linux means Freedom of Choice"
#17
Posted 14 April 2008 - 02:39 AM
ASUS's xandros is a lightweight version of xandros. Compared with the stardard version of xandros, it's missing
- no multi-user
- no screensaver
- no save session
- has /home/user by default instead of /user/[username]
- no large repositories (like debian)
- etc
If you want to see what standard xandros looks like, download xandros 4 OCE from http;//geekconnection.org . Unfortunately,
it's an install CD, not a live CD. In other words, ASUS really trimmed xandros for the eee.
Sheng-Chieh
#18
Posted 14 April 2008 - 03:43 AM
