Allow me to thank Directron.com for this unit that I upgrade to the max. My work place is a truly fantastic computer store full with wonderful people. Btw, black EEE PC units are coming to our store on 16th, pre-order for now.
Came home to find this:
The card is very small but thicker than the original because of the plastic:
Extra antenna, EEE PC has two, this one makes three:
This is N card that needs three antennas to function:
First I removed keyboard by depressing marked tabs, then unscrewed exposed screws:
Mousepad and keyboards are easily disconnected but be very gentle:
These ribbons are easy to damage:
On reverse side remove RAM and unscrew (here you see my 2GB of RAM):
Here you will need a tiny flat-head to snap-out cover all around, don't leave marks, have proper tools, easy with audio ports:
Screen is a pain to open, it holds mainly on snapped plastic tabs than screws, very easy to damage the frame:
Here is your toy with the dress off:
http://www.derectron.../eeehack/11.jpg
Motherboard is held by 2 plastic tabs near the mouse pad, un-snap and help the ports to clear from their housing:
http://www.derectron.../eeehack/12.jpg
Here is the offending G wireless card to replace (it is still working but not the best my EEE PC deserves):
http://www.derectron.../eeehack/13.jpg
Here is a closer view of the fan, it is a bit thick and blows only on the bottom of the motherboard when CPUs and bridge are on the top... ???:
http://www.derectron.../eeehack/14.jpg
Sorry for the poor pics here, my room is not well lit for this purpose, here you see two mini PCIe ports, one is occupied by the WiFi card:
http://www.derectron.../eeehack/15.jpg
The old card is removed, 2 antennas disconnected:
http://www.derectron.../eeehack/16.jpg
Here is the back of the old card:
http://www.derectron.../eeehack/17.jpg
This chip (resistor?) really is in the wrong place, it very hard now pushes against my current card, I repeat - with force is embedded now in my current new WiFi card:
http://www.derectron.../eeehack/18.jpg
After the installation of the new card and new 3rd antenna:
http://www.derectron.../eeehack/19.jpg
Boy, it was not easy to route it to the side, the other side of LCD is less busy but antenna is short and can be positioned only here:
http://www.derectron.../eeehack/20.jpg
Here is the connection to my N-Router DLink DIR-655
http://www.derectron.../eeehack/22.jpg
Edited by TexasGuy, 14 November 2007 - 08:06 PM.
