SDLMame or XMame on Xandros?
Posted 12 March 2008 - 06:05 PM
Problem is, this is the first time I've ever even touched a linux build. I dont even know where to start. All this talk about repositorys and tars has given me a headach and has made me want to install XP.
Anyone have a "for complete idiots" guide to getting SDLMame or XMame installed?
Posted 13 March 2008 - 05:52 AM
Posted 13 March 2008 - 06:18 AM
as much as I like Xandros, i think I'll be putting XP on my eee pc. Playing shockwave games and mame was one of the major things I was looking to do with it in my uhm... "unproductive" hours
Posted 13 March 2008 - 06:20 AM
Install the packages by starting up a terminal and typing:
sudo dpkg -i xmame-sdl.deb
sudo dpkg -i xmame-common.deb
Then run it by typing xmame.SDL -rp <path to roms> <rom name>
SDLMame debian package you can geta at package.ubuntu.org. Its up to date I believe but my roms aren't.
Posted 02 April 2008 - 07:34 PM
thank you
TOTO
Posted 02 April 2008 - 08:57 PM
Ubuntu 10.04, FluxBox, Conky, all repos locally mirrored
Posted 02 April 2008 - 10:24 PM
http://wiki.eeeuser.com/ <-- A searchable knowledge base; very helpful for beginners!
Posted 03 April 2008 - 02:08 PM
Sunset Riders
TMNT (1 and 2)
Dungeons and Dragons (1 and 2)
Last Blade (1 and 2)
Metal Slug (1, 2, X, 3 and 4)
Battletoads
Posted 03 April 2008 - 08:00 PM
Posted 12 May 2008 - 11:57 PM
I've taken the liberty to start a wiki page on this, if anyone would like to add to it/clean it up, as I think getting MAME running on a stock EeePC is something lot of people would be interested in:
http://wiki.eeeuser....to:install_mame
Thanks Von Floppy!
Posted 15 May 2008 - 01:37 AM
I ended up taking a different approach, though. I downloaded and compiled sdlmame. It took a loooong time, but finally gave me the 30mb mame binary. Now I'm using the XLAMEGUI java front-end.
sdlmame is nice because it allows you to dynamically resize the mame window in the normal way (no need to mess with command-line parameters). So I can run a ROM and then just re-size the window to my liking.
I've got everything on a SD card and it seems to work just fine. Cool! :D
Edited by windracer, 15 May 2008 - 01:37 AM.
Galaxy Black 4G Surf - SOLD
Shiny White 900A - SOLD
#12
Posted 19 September 2008 - 02:41 PM
/home/user> sudo dpkg -i xmame-sdl_0.106-2_i386.deb
Selecting previously deselected package xmame-sdl.
(Reading database ... 72575 files and directories currently installed.)
Unpacking xmame-sdl (from xmame-sdl_0.106-2_i386.deb) ...
dpkg: dependency problems prevent configuration of xmame-sdl:
xmame-sdl depends on xmame-common (= 0.106-2); however:
Package xmame-common is not installed.
dpkg: error processing xmame-sdl (--install):
dependency problems - leaving unconfigured
Errors were encountered while processing:
xmame-sdl
/home/user> sudo dpkg -i xmame-common_0.106-2_all.deb
Selecting previously deselected package xmame-common.
(Reading database ... 72578 files and directories currently installed.)
Unpacking xmame-common (from xmame-common_0.106-2_all.deb) ...
dpkg: dependency problems prevent configuration of xmame-common:
xmame-common depends on xmame | xmess; however:
Package xmame is not installed.
Package xmame-sdl which provides xmame is not configured yet.
Package xmess is not installed.
Package xmess-x which provides xmess is not configured yet.
dpkg: error processing xmame-common (--install):
xmame-common
Does anyone have some suggestions? Where would I go to configure xmame? I'm not sure what step I'm missing.
Thanks,
- Robert :)
#13
Posted 19 September 2008 - 07:07 PM
sudo dpkg -i xmame-sdl_0.106-2_i386.deb xmame-common_0.106-2_all.deb
#14
Posted 23 September 2008 - 03:19 PM
In xmame I can't seem to get both fullscreen and correct aspect ratio, particularly with cps2 games.
Meanwhile, sdlmame, which is my preferred choice, doesn't quite run as smoothly as it should. I end up overclocking and auto frameskipping to get reasonably smooth gameplay. Neo Geo games are the ones running slower, by the way.
For instance, with Metal Slug, the game most of the time runs OK with 5-6 frameskip, but once things get ugly (such as the boss of level 1) and there are many sprites running around, frameskip jumps to 10 (the limit) and then there is a very noticeable slowdown of gameplay (about 80% speed).
I tried compiling sdlmame myself with no apparent improvement (it looks like it is compiled with -O3 by default, so that's not a surprise).
One little trick I found, though: sdlmame will run at about half a frame per second with the default opengl renderer. Change it to opengl16 to get a major fps boost (it's still not good enough for me, I'm afraid).
Reading here that people are getting good speeds with Neo Geo games, is there anything I'm missing?
