Theme: 'Minifox'. Minifox is a theme that uses very small, but still usable icons.
Extensions: 'Compact Menu 2'. Takes the Menu Bar's contents and creates a drop-down button instead to minimize the area used by the Menu Bar.
'Full Fullscreen'. Allows you to remove the scroll bar, tab bar and status bar in full-screen view so you see nothing but the content of a web page on screen.
'Searchbar Autosizer'. Makes your searchbar grow as you type information into it. Customizable so that you can determine the smallest and longest the bar can grow to.
'Smart Bookmarks Bar'. Takes away the text from your Favourites' icons and then minimizes the space between them to maximize how many are viewable at anytime. Also has the ability to automatically 'hide' your bookmarks bar and show it again when you hover your mouse over the bookmarks toolbar area.
I also do the following:
1. Right-click on the Menu Bar and select 'Customize...'
2. Select 'Use Small Icons'
3. Click-and-drag any icons you don't need off of the toolbar(s). I removed the stop, refresh and home buttons. (Instead of stop, press 'esc'; instead of refresh, press 'F5' or 'Ctrl-F5'; and instead of home, press 'Alt-Home')
4. Click-and-drag the Compact Menu to the upper left corner.
5. Click-and-drag the back and forward buttons to the right side of the compact menu button.
6. Click-and-drag the Address Bar and Search bar to the right of the back and forward buttons.
7. Add a '+Tab' button to the Bookmarks Toolbar.
8. Click 'Done'.
9. Right click the now empty Navigation Toolbar and uncheck 'Navigation Toolbar'.
Here's a preview of how mine looks:
Also remember that you can press the arrow on the bottom right of your screen (if you're using the default Xandros install as well as other linux distros) to hide the task bar. In XP you can use the 'Autohide task bar' feature too.
And for those of you new to the F11 button. Try it. It will put you into full-screen mode and back again the easy way!
If anyone else has any other tips let me know!
