Ubuntu shutdown problem
36 replies to this topic
#1 ma10
  • 89 posts
Posted 11 November 2007 - 01:09 AM
I'm not sure if everyone is still having problems shutting down (appears to go to standby instead, blank screen + green power led lit) but I think I managed to solve mine.... not sure what I did cause I tried lots of things suggested by a bug posted on launchpad, namely:
https://bugs.launchp....22/+bug/119308
The one I suspect that did the trick was suggested by a user called larryleezard:
1. edit /etc/init.d/halt script:
sudo gedit /etc/init.d/halt
2. add the following to the top of the script:
rmmod snd-hda-intel
3. save and finally try and shutdown ubuntu..........
Can you guys confirm if this has already been posted and/or solves the shutdown issue please??
Edited by ma10, 11 November 2007 - 01:10 AM.
4GB Black eee - XP & Heron - MODS: Touchscreen, int SD, int 8gb OCZ usb, int bluetooth + extra int usb port
Advent 4213 AKA ECS G10iL - Triple booting XP, Ubuntu and Leopard OSx
#2 SmallFootprint
  • 102 posts
Posted 11 November 2007 - 03:10 AM
Seems to have solved the problem for me, thanks!
#3 quagga
  • 411 posts
  • LocationVirginia, Earth
Posted 11 November 2007 - 03:11 AM
Works for me too. Thank you!
#4 ma10
  • 89 posts
Posted 11 November 2007 - 02:37 PM
no probs! I can add this to the list of things to do if I need to reinstall Ubuntu Gutsy again. :)
#5 stampedingchipmunk
  • 27 posts
Posted 11 November 2007 - 02:46 PM
worked for me as well. Thank you so much!
#6 rozojc
  • 162 posts
Posted 11 November 2007 - 03:59 PM
Well, since several people reported it worked, I just added this solution to the Wiki, in the section of Installing Ubuntu (http://wiki.eeeuser.com/ubuntu). Great work!
#7 Triarm
  • 10 posts
Posted 11 November 2007 - 10:47 PM
Another confirmed working case.
Rather than adding it to the top of the initscript, I threw it in /etc/defaults/halt. This file gets sourced by the initscript and looks less likely to be overwritten by an update.
#8 kwikbreaks
  • 86 posts
  • LocationChapel Brampton
Posted 15 November 2007 - 10:37 AM
Another happy customer.
Complete Linux newbie and I wasn't sure if the command would need the path which is at the top of the script so I put it as first line in the do_stop function.
Off topic bit so please don't respond to it here....
Now to get on with - wireless still not working even with ndiswrapper stuff done and a virtually unusable trackpad that seems to be inventing double clicks when none were intended :(
Mark
I bought the eee mainly for use with Amateur Radio DigitalHam
#9 Muhahahahaz
  • 89 posts
  • LocationCA, USA
Posted 10 December 2007 - 05:07 AM
At first I didn't even notice that it wasn't shutting down all the way, but sure enough the power light was staying on!
I am here to confirm that this works for Kubuntu 7.10. Good work! :)
#10 sex4quarters
  • 4 posts
Posted 12 January 2008 - 12:06 AM
worked for me on gutsy
#11 devitt
  • 9 posts
Posted 13 January 2008 - 10:36 PM
In eeexubuntu r3 on eeepc adding the line to the beginning (I assume it should be after the # comment lines) made it work once.
Now clicking Applications Shutdown does nothing. Before I had to click it twice to get the shutdown options, but now I have to run sudo shutdown -h now from a terminal to shut down.
Any ideas please?
RossD
Added:
It gets better. Now on some shutdowns the shutdown options come up, but when I shut down I am back to the light (and fan if it is running) staying on, and I have to press the power button.
Weird!
lol
Edited by devitt, 13 January 2008 - 10:52 PM.
#12 pcipronet
  • 3 posts
Posted 14 January 2008 - 04:52 AM
I'm have the same unresolved problem in eeeXubuntu.
#13 moderndrummer
  • 2 posts
Posted 27 February 2008 - 09:35 AM
I usually get some strange characters flashing on my screen when i try to shutdown eee ubuntu. I tried the "shutdown" hack to add rmmod snd-hda-intel in /etc/init.d/halt and though i CAN shutdown 50% of the times, the other 50% i get those flashing chars and the eee pc freezes..
what;s more, when i try to restart it after i force it to shutdown by holding the power button, it boots to half the "boot progress bar" (the ubuntu screen) then it restarts and then it boots normally. the same thing happens if i run out of battery. in other words it happens every time the machine doesn't shut down properly...
any ideas / fixes??
thanks a lot in advance, so happy to be among you people :D
#14 kajer
  • 143 posts
Posted 27 February 2008 - 12:48 PM
i did that mod before I even shutdown for the first time... never had an issue with shutting down 7.10
DO NOT USE 30awg wire for USB power!!! Trust me, I know.
#15 inorman
  • 23 posts
Posted 27 February 2008 - 11:37 PM
any ideas / fixes??
I also get the same problem on eeebuntu. Not sure of a fix yet. Anyone else get the flashing chars on some shutdowns??
Eee 4G Surf - Overclocked to 900MHz, 2GB RAM
Ubuntu 8.04 Hardy Heron
#16 schwieb
  • 127 posts
  • LocationNorth Carolina
Posted 28 February 2008 - 01:29 AM
You asked, so I thought I would confirm that this fix is listed in a few other places:
https://help.ubuntu....community/EeePC
http://wiki.eeeuser....roff_workaround
The fix should work for any version of Ubuntu.
It's not the size of your computer that matters, it's how you use it!
#17 tech-geek
  • 15 posts
  • LocationOhio, USA
Posted 08 March 2008 - 04:30 PM
any ideas / fixes??
I'm using Kubuntu and I get the same flashing characters on shutdown, logout, or reboot on random occasions. It's really a pain because it seems to munch some of the kde panel/toolbar preferences. I added the rmmod fix early in my setup process but the crash still happens every few days. I can't figure out what causes this issue.
#18 markp1989
  • 500 posts
Posted 08 March 2008 - 10:08 PM
worked for me thanks
worked on the first shutdown, didnt help next time, but then it helped the time after:S
Edited by markp1989, 08 March 2008 - 10:14 PM.
White 4g 701, 2gb RAM. 16gb sdhc ,Touch Screen, draft-n , tablet mod (topic=66842) eeectl 360-900mhz
Acer Aspire 3810TZ Ubuntu 10.10
Desktop: Intel i7 875K - 4gb ram - 64gb SSD - Nvidia 8800
HTPC: E3300 - 4gb ram - 32GB SSD - 2 * 1.5tb hd
#19 tech-geek
  • 15 posts
  • LocationOhio, USA
Posted 17 March 2008 - 12:06 PM
I just thought I'd update this post in case anyone is still having problems. I've spent the last week stress testing my kubuntu image before I roll it out to our 8th grade lab and everything seems to be working as it should. I reinstalled the sound portion of the ubuntu script pack and thing seem to be fixed.
sudo ./install.sh sound
I've done multiple shutdowns, reboots, and sleeps each day trying to force the the issue to reoccur, but it hasn't. (Knock on wood!)
BJ Thaman
#20 You
  • 3 posts
Posted 17 March 2008 - 04:54 PM
Great fix!
Fixed my issue as well.
