I am a bit worried about my battery, though. Maybe it's just the kernel acpi that's wrong, but this is what I get:
/home/user> cat /proc/acpi/battery/BAT0/state present: yes capacity state: ok charging state: charged present rate: unknown remaining capacity: 100 mAh present voltage: 8299 mV /home/user> cat /proc/acpi/battery/BAT0/info present: yes design capacity: 5200 mAh last full capacity: 100 mAh battery technology: rechargeable design voltage: 8400 mV design capacity warning: 10 mAh design capacity low: 5 mAh capacity granularity 1: 52 mAh capacity granularity 2: 52 mAh model number: 701 serial number: battery type: LION OEM info: ASUSThe battery GUI says it's fully charged... but the remaining capacity says 100 mAh... which falls short of the "5200 mAh" by more than a factor of 50. Anyone else see this in their acpi output?
Just wondering if it's an actual battery problem.. or if the kernel isn't getting the battery info correct.
Thanks.
