Portable Linux programs for Eee with Xandros Linux , do they exist ?
Posted 13 February 2008 - 01:48 PM
Windows has a LOT of freeware and opensorce applications
that work portable (No setup/no install needed)
Sorry if this has been asked before . It would be handy to store
linux applications along with Windows apps in portable format
on a USB stick .
This way if anyone needs to reset the EEE you dont lose all the programs
nor have to go thou the hassle of reinstalling everything
Posted 13 February 2008 - 02:21 PM
You can quite easily squeeze Ubuntu, for instance and a moderately hefty set of applications onto a four gig USB drive and still have plenty of document space. If you use a *small* linux distribution like DSL or Puppy Linux (e.g. the Breeezy project), then even on a 1GB USB, you could store a number of applications and documents in addition to the OS.
If you're willing to make some sacrifices on boot time, you can do this using a Live / Persistent type of installation (see http://pendrivelinux.com for examples). The advantage is that it will boot successfully from almost any Intel-based computer. Alternatively you can just format the USB as ext2 or ext3 and install a Linux distribution on it just as if it were the internal drive, and it will be significantly faster, but customized to your Eee....
From what I've seen, there isn't currently a working repository of easily installable Linux portable binaries, today.
Is a bootable USB an option?
Posted 13 February 2008 - 02:37 PM
on a USB stick .
Posted 13 February 2008 - 02:40 PM
Posted 13 February 2008 - 03:12 PM
Posted 13 February 2008 - 03:16 PM
I am guessing the way GNU/Linux is setup it doesnt support
running un-istalled apps/games which is a shame , theres a huge
push on Windows for portable apps more and more lately .
Windows still does for me have some good advantages at times
(eg portable apps , certain FREE apps that isnt on Linux/Mac)
Currently using NLITED custom Windows 2003 on my file server
and gaming box and using the default Linux on the EEE .
Ive learn more about Linux after using the EEE but having
portable apps on linux would make using Linux a whole lot better in my view.
Posted 13 February 2008 - 03:40 PM
Posted 14 February 2008 - 06:40 AM
Some softwares also have static binary available for download, e.g. xnview static. They are just not popular because there are too many different Linux distro with different libraries need to run in that distro. So, unless that program require just a few libraries (that does not change very often), then you can compile a static binary.
It would be good if we can establish a download source for such static binaries for the Eeepc.
Posted 14 February 2008 - 10:47 AM
To compile softwares from source code as static, I remember we add this flag during compiling:
make LDFLAGS=all-staticBut I have not been doing this for a few years already (just using software packages other people have compiled), so I am not sure if this is correct for the latest version of gcc compiler. May be some other Linux users can confirm this.
going from install only to this static/portable run method ?
Using a gui program or script ?
Posted 15 February 2008 - 06:06 AM
I'd be surprised if you don't see me posting links to some klik(2) debs tested on the eee before fosdem, though no promises. I'm leaning towards ignoring the AsusLauncher now and not introducing any code to mess with simpleui.rc unlike in the screenshot.
#12
Posted 15 February 2008 - 05:42 PM
http://pafl.portools.com/
#13
Posted 04 January 2009 - 06:56 PM
IceWeasel portable, IceDove portable, OpenOffice 3 portable, IceOwl portable, and X Term portable.
VLC and mplayer are to come soon.
http://portools.com/apps
<edit> In fact, there are really more apps to come:
http://portools.com/.../topic.php?id=3
IceWeasel (a.k.a. Firefox) - web browser
IceDove (a.k.a. Thunderbird) - email client
IceOwl (a.k.a. Sunbird) - task management
OpenOffice.Org - office on the go
XEmacs - full-featured text editing
GIMP Image Editor - image editor
Pidgin - instant messaging client
Kompozer - web designing
FileZilla - FTP client
Celestia - space simulator
Audacity - audio editing
Avidemux - video editing
MPlayer - multimedia viewer
VLC - multimedia viewer
Abiword - text editing
GnuCash - finance management
XPDF - pdf viewing
Task Coach - task organizer
Keepass - password safe
Frozen Bubble - fun, arcade based game
SuperTux - exciting Mario-like game
Frets on Fire - game like Guitar Hero
Edited by oupsemma, 04 January 2009 - 07:29 PM.
#14
Posted 07 January 2009 - 04:56 AM
This creates the problem that you now need Java installed. Oh but wait you can get Java to be portable, now the only thing you need is to have a different version of Java for each OS you plan to use. Depending on how many applications you would use this might take up less space than having the application installed to your flash drive 5 different times.
The big problem. most things are not written in Java and those that are are badly written and buggy or run incredibly slow. In a perfect world, Java would not take 200M pe install, and more apps would be coded in it.
All this in mind a good OS bootable flash drive really is the best answer, even though not all machines will let you boot off the drive, it's probably going to get you farther than installing the apps on your flash drive several times.
You can contribute this to the lack of hardware standards, big corporations not wanting to play nice with each other nor with the open source community, and Intel's horrid idea of just stacking new features into the x86 instead of just making a new processor that works better and saying tuff to the big OS corps.
But if you have a netbook, you can just about carry it in your pocket and not need to worry about all this.
#15
Posted 07 January 2009 - 11:44 AM
Anybody got them working?
#16
Posted 07 January 2009 - 12:33 PM
To have it running, I had to go to the following file (after having given me all the necessary permissions on its files and sub-files!):
IceWeaselPortable-3.0.4 / App / usr / lib / iceweasel / iceweasel
it's this 8.4 KB shell script that you have to click on and run. And funnily, it is not labelled as iceweasel.sh. It's the file that is in the 6 files after the xulrunner folder.
On the PortableApps for Linux site's forum, it seems that some fixes will be done for the next release http://portools.com/forums/
Edited by oupsemma, 07 January 2009 - 12:34 PM.
#17
Posted 15 January 2009 - 06:08 AM
#18
Posted 15 January 2009 - 08:07 AM
Best regards,
Malcolm
www.freepoc.org
#19
Posted 16 January 2009 - 12:24 PM
I don't want to use a framework, so I think there is a space for native Linux portable apps (semantics aside) because as a technology business owner, and a Linux shop, I want to be able to give new joiners to my business a USB memory stick and say "pick a machine..." Imagine if your staff could carry their work everywhere (settings, apps and all) on a USB stick and sit down at any Linux workstation, anywhere in the world. With Windows they can. I think Linux needs to be able to boast the same.
And I *really* want to be able to swap apps between my laptop and EEE PC like this. =)
#20
Posted 16 January 2009 - 12:29 PM
