http://code.google.c...scantool-eeepc/
You need a compatible OBD-II interface first before you can use this program. I tested this with my ELM327 chip via Bluetooth.
ScanTool for EEE-PC is a modified version of ScanTool. It can be used with compatible OBD-II (On Board Diagnostic) chip to read trouble code from an OBD-II compatible vehicle. It can also read real-time data such as "Engine RPM", "Intake Air Flow (MAF)", "Fuel trims" and etc.
The reason why it was modified is because the original ScanTool would not work or run on ASUS EEE-PC's native resolution of 800 x 480. On a 7 inch monitor, the sensor outputs would be too small for users to read, especially while driving. Some of the sensor names were too long, so when the fonts were enlarged, they simply cannot fit into the screen.
I have tried some OBD-II software, most of them either don't work well with the 7 inch screen, or they are not open-source. The goal of this project is to modify this wonderful software usable on an ultra portable laptop such as the ASUS EEE-PC since they can be mounted right on the dash of a car.
ScanTool for EEE PC
Started by devil2k, Feb 02 2008 07:09 AM
7 replies to this topic
Posted 02 February 2008 - 07:09 AM
Posted 24 February 2008 - 02:30 AM
That's really cool are you using the stock eee os or windows? I'm a automotive technician and I got the eee to use around the shop it would be great to use it as a scanner also. What cars have you used it on so far?
Craig
Craig
Posted 26 February 2008 - 04:04 AM
I'm using windows xp. ScanTool seems to be for windows xp only but the library it depends on works on multiple platform. I haven't looked into porting it, yet. It might not be hard at all but I don't have the stock Xandros linux anymore. I've worked on my 04 Mazda 3 and my friend's 06 Honda Civic so far. Right now I'm working on the fuel efficiency part. It's done but I haven't had to chance to test it, yet. I should get it tested before Saturday of this week and release the next version. Thanks for the support. I'm surprised that someone actually responded to this thread :)
Posted 01 March 2008 - 02:59 AM
2nd release with fuel efficiency gauge
Posted 05 July 2008 - 02:59 AM
I've written a wiki article explaining how to build ScanTool for Linux on the EeePC.
http://wiki.eeeuser.com/howto:scantool
ASUS 4G 701 (7B) black, 2GB ram, BIOS v0910, DebianEeePC v5.0 (Lenny) from image 20081207 installed to SSD, with xfce4 v4.4.2. Lean and mean!
Posted 09 July 2008 - 06:34 AM
i love you. you wouldnt happen to know where i can get a cable for OBD-II to USB cable would you?? :) i am a young technician (17 years young) ive been trying to look for a cable of that type... or better yet what kind of linkage do you use??
[701 4G BLK][XP Pro @#Edition][2G 667 RAM Crucial]
Posted 09 July 2008 - 01:19 PM
I use a cheap eBay bluetooth OBD2 adapter based on ELM327 chip. I got it for around $150 and it was shipped out of Vancouver. It might be cheaper now.
Posted 12 July 2008 - 05:37 PM
Here is what I bought on EBay. Cost me $33 US.
http://cgi.ebay.com/...em=220248513554
Just search EBay for "ELM327 USB".
