eeeXubuntu shutdown issue
19 replies to this topic
#1 Atomoton
  • 3 posts
Posted 08 January 2008 - 11:44 PM
I just got my EEE yesterday and spent all of 5 minutes on the Xandros system before rushing off to change it.
After a long and intimidating install process involving a few different distros (MINT, UBUNTU, and eeeXUBUNTU) i finally got eeeXubuntu to work with no problems, and am enjoying it now. I've only altered a few settings, nothing that should affect shutdown as far as I know, but hey...
The issue: It started only after installing the new OS (of this I'm about 90% sure). The problem is when I select shutdown, it shuts down fine, but the little green light with the lightbulb symbol is still on, and the fan is still running. I can still hold down the power button for a few seconds to turn it off fully, otherwise it just sits there. So my questions are is it safe to shut it down like that, and how can I stop it from doing this? Any help is greatly appreciated.
#2 aplus01
  • 12 posts
  • LocationSan Diego, CA
Posted 09 January 2008 - 12:00 AM
mine does the same thing. i just do a hard reset and everything is fine, but i too would like a fix for this.
#3 ShaqARif
  • 383 posts
  • LocationLondon
Posted 09 January 2008 - 01:17 AM
On Ubuntu/Xubuntu, the following works for me:
Edit the file /etc/default/halt
add the following line right at the end:
rmmod snd-hda-intel
don't know if this will work for eeeXubuntu, but it's worth a go.
I got this fix from someone else on this forum.
---- eee pc 901 Glossy Black 1GB RAM 4/8GB SSD --------- CrunchBang Linux (adamms kernel) ------
#4 jakub
  • 13 posts
Posted 09 January 2008 - 02:33 AM
Cool, worked for me as described. Awesome, thanks!
#5 reventlov
  • 14 posts
Posted 09 January 2008 - 06:12 AM
This worked for me, too. Thanks for passing along the info, ShaqARif.
#6 wamser_e
  • 101 posts
Posted 09 January 2008 - 07:05 AM
Worked like a champ. Thanks Shaq!
#7 ShaqARif
  • 383 posts
  • LocationLondon
Posted 09 January 2008 - 11:48 AM
Glad to be of service!
Seems this question comes up quite frequently, so I've added it to the FAQ.
#8 aplus01
  • 12 posts
Posted 09 January 2008 - 04:52 PM
ditto. thanks!
#9 ch0mik
  • 30 posts
  • LocationPoland, Koluszki
Posted 09 January 2008 - 06:46 PM
Hi, it works ;) with Debian Lenny installed on SDHC
/etc/default/halt
rmmod snd-hda-intel
701A,1GB-RAM, 8GB-SDHC, Mandriva 2008.1 (SSD+SDHC:LVM); Crystal Case
#10 Aztec
  • 48 posts
Posted 09 January 2008 - 07:08 PM
The same problem started for me when I went from eeeXubuntu R2 to R3. I'll try this fix tonight. What exactly does it do?
#11 Atomoton
  • 3 posts
Posted 11 January 2008 - 05:42 AM
Ah thanks a lot. Might also be intereting to note that this only happens whe you shut down while connected to a network.
#12 njp
  • 16 posts
Posted 11 January 2008 - 09:35 AM
Worked for me too - thanks.
P.S. Where is the FAQ? I didn't find it on the Wiki pages...
Edited by njp, 11 January 2008 - 09:37 AM.
#13 clovis_ll
  • 30 posts
  • Locationsan francisco, ca
Posted 03 February 2008 - 08:34 PM
didn't work for me. i can edit it but i can't seem to save it.. any ideas how you guys figured it out?
"See daddy? All the keys are in alphabetical order now."
#14 Kartikay
  • 20 posts
  • LocationPahoa, HI
Posted 03 February 2008 - 09:05 PM
You need to edit the file as root to save it. Try this
sudo mousepad /etc/default/halt
Deeesktop Pictures for You!
http://picasaweb.goo...ount/Deeesktops
#15 colasanti
  • 2 posts
Posted 05 February 2008 - 10:01 AM
Working with ubuntu I found that this solution stopped the sound card from being recognized. However I found that in correcting a problem with USB memory recognition :
sudo nano /etc/fstab
Comment out this line with a #:
/dev/sdb1 /media/cdrom0 udf,iso9600 user, noauto, exec 0 0
did solve this problem as well.
This Kind of makes sense as it would still be looking fro the attached CD rom to power.
Any way lucky accident on my part that may help others
All the best
#16 colasanti
  • 2 posts
Posted 05 February 2008 - 10:04 AM
My apologies for double posting but on rereading my above comment I realized that it was not as clear as I wanted.
The USB fix also fixed the power shut down not the sound card problem this was souled bu NOT altering the halt file
#17 jojmoj
  • 9 posts
Posted 16 March 2008 - 08:00 PM
works like a absolute beeeauty!!! thanks a lot... this was starting to get on my proverbials...
mega thnx here :D
#18 leon5139
  • 1 posts
Posted 08 August 2008 - 09:49 PM
hi guys. i am new to this forum and to linux. I installed eee ubuntu and get the green light staying on after "shutdown". i am new to using the terminal function and have tried following your instructions but have had no success. When i use sudo mouse i get an improper function message. I have been having problems getting the grasp of editing these functions and saving them
any help would be gratly appreciated
#19 speedx
  • 21 posts
Posted 20 August 2008 - 12:19 PM
i think its case sensitive! some1 can correct me if i am wrong!
#20 triblinator
  • 65 posts
Posted 23 August 2008 - 04:34 AM
Are you actually typing mouse, or is that an abbreviation? You need to open the file in a text editor with root privelage, so type "sudo mousepad /etc/default/halt" then the location of the file - not just sudo mouse. Hopefully your problem is as simple as that.
Edited by triblinator, 23 August 2008 - 04:35 AM.
